[GRASS5] problems compiling GRASS on SuSE 8.2
Marco Lechner
marco.lechner at urz.uni-heidelberg.de
Thu Feb 3 08:26:40 EST 2005
Hi list,
After hours of compiling with different options I still get this
error-message after starting GRASS and having chosen the mapset/location:
GRASS 6.0.0beta1:/usr/local/grass60/bin > Error in startup script: ps.map:
error while loading shared libraries: libgdal.so.1: cannot open shared
object file: No such file or directory
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 31)
invoked from within
"main $argc $argv"
(file "/usr/local/grass60//grass-6.0.0beta1/etc/dm/d.m.tcl" line 890)
but libgdal.so.1 is in /usr/local/gdal/lib/
libgdal.la libgdal.so libgdal.so.1 libgdal.so.1.6.0
gdal-config seems to be correct:
CONFIG_LIBS="-L/usr/local/gdal/lib -lgdal"
CONFIG_DEP_LIBS="-L/usr/local/lib -lgeos -lodbc -ljpeg -lpng -lz -lm -ldl -L
/usr
/lib -lpq "
CONFIG_PREFIX="/usr/local/gdal"
CONFIG_CFLAGS="-I/usr/local/gdal/include"
CONFIG_VERSION="1.2.5"
A few more hints:
I tried compilation with the GRASS 6.0.0beta1 and the CVS-Snapshot from Jan
25th. with the follwoing options:
./configure --with-cxx --with-odbc --with-blas --with-blas-libs=/usr/lib/ -
-with-lapack --with-motif --with-readline --with-freetype=yes --with-freety
pe-includes=/usr/include/freetype2 --with-mysql --with-mysql-includes=/usr/i
nclude/mysql/ --with-nls --with-gdal=/usr/local/gdal/bin/gdal-config --with-
postgres-includes=/usr/include/pgsql --with-postgres-libs=/lib/ --with-proj-
includes=/usr/local/proj/include/ --with-proj-libs=/usr/local/proj/lib/ --wi
th-glw --with-glw-libs=/usr/local/lib --with-glw-includes=/usr/local/include
--enable-64bit --prefix=/usr/local/grass60./configure --prefix=/usr/local/g
rass60/ --with-postgres-includes=/usr/include/pgsql/
configure works:
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /nfs/u1/software/grass/grass-6.0.0beta1
Build directory: /nfs/u1/software/grass/grass-6.0.0beta1
Installation directory: /usr/local/grass60/grass-6.0.0beta1
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
FORTRAN compiler:
Building shared libraries: yes
NVIZ: yes
X11 support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: yes
OpenGL(R) support: yes
ODBC support: yes
FFTW support: yes
BLAS support: yes
LAPACK support: yes
Motif support: yes
FreeType support: yes
GLw support: yes
NLS support: yes
Readline support: yes
C++ support: yes
openDWG support: no
GDAL support: yes
OGR support: yes
make has first problems in GRASS_SRC/lib/proj:
GRASS GIS compilation log
Started compilation: Thu Feb 3 14:00:52 CET 2005
Errors in:
/nfs/u1/software/grass/grass-6.0.0beta1/lib/proj
Finished compilation: Thu Feb 3 14:08:56 CET 2005
make in ...lib/proj says (no idea):
saone:/u1/software/grass/grass-6.0.0beta1/lib/proj # make
install -m 644 datum.csv gdal_datum.csv projop_wparm.csv ellipsoid.csv
pcs.csv stateplane.csv gcs.csv prime_meridian.csv unit_of_measure.csv
/nfs/u1/software/grass/grass-6.0.0beta1/dist.i686-pc-linux-gnu/etc/ogr_csv
if I start make again it works without errors:
Started compilation: Thu Feb 3 14:17:34 CET 2005
Errors in:
Finished compilation: Thu Feb 3 14:18:14 CET 2005:
make install goes without problems, but the message on top still apears.
any ideas?
Marco
Marco Lechner
dienstlich:
Institut für Physische Geographie
Uni Freiburg
Werderring 4
79085 Freiburg
Fon 0761 / 203-3548
Mail marco.lechner at geographie.uni-freiburg.de
privat:
Höfnerstr. 6
79199 Kirchzarten
Fon 07661 / 907783
Mail marco at marcolechner.de
