[GRASS5] problems compiling GRASS on SuSE 8.2
Glynn Clements
glynn at gclements.plus.com
Fri Feb 4 06:22:14 EST 2005
Marco Lechner wrote:
> After hours of compiling with different options I still get this
> error-message after starting GRASS and having chosen the mapset/location:
> GRASS 6.0.0beta1:/usr/local/grass60/bin > Error in startup script: ps.map:
> error while loading shared libraries: libgdal.so.1: cannot open shared
> object file: No such file or directory
> but libgdal.so.1 is in /usr/local/gdal/lib/
> libgdal.la libgdal.so libgdal.so.1 libgdal.so.1.6.0
You probably need to add /usr/local/gdal/lib to /etc/ld.so.conf then
re-run ldconfig.
