[GRASS5] vector import, howto
Michael Barton michael.barton at asu.edu
Sun Feb 6 11:18:16 EST 2005
This has appeared in several recent postings. Also one of my grad students
reported identical problems where he'd been able to do the same kind of
import a couple months back.
Given the little bit of discussion, I'm beginning to suspect that it is a
quoting issue that may be primarily a problem with the TclTk GUI or may also
affect the command more broadly.
Here are a couple suggestions.
1) If you have not done this already, try it from the command line rather
than just from the GUI.
2) Try with different delimiters than |. Maybe try a comma ",".
Let us know what happens.
Michael
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
> From: Peter Löwe <peter.loewe at gmx.de>
> Date: Sat, 5 Feb 2005 15:06:00 +0100 (MET)
> To: <grass5 at grass.itc.it>
> Subject: [GRASS5] vector import, howto
> Dear List:
> I am trying to ingest a ASCII-CSV-List into GRASS 6beta1.
> The list conists of lines which look
> like
> this:
> 900000001|09|1|79|149|001||10||4431350.18|5329876.12|Sankt-Ottilien-Straße|822
> 99|Türkenfeld|b
> Furstenfeldbruck
> The coordinate info sits in the fields tent and eleven
> (4431350.18|5329876.12), "category" resides in field one.
> The locations database is dbf:
> GRASS 6.0.cvs:> db.connect -p
> driver:dbf
> database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> schema:(null)
> group:(null)
> The first attempt was made through v.in.ascii, since its HTML-Documentation
> gives a similar example (at the very bottom of the HTML-document)
> GRASS 6.0.cvs:~ > v.in.ascii in=adressen_grass.txt out=adr_dbx1
>  y=11 x=10 cat=1 columns='cat int, var2 int, var3 int, var4 int,
>  var5 int, var6 int, var7 varchar(3), var8 int, var9 varchar(4), x
>  double, y double, var12 varchar(30),var13 int,var14 varchar(30),var15
> varchar(40)'
> This approach fails:
> WARNING: DOS text format found, attempting import anyway
> Maximum input row length: 115
> Maximum number of columns: 15
> Minimum number of columns: 15
> column: 1  type: integer
> column: 2  type: integer
> column: 3  type: integer
> column: 4  type: integer
> column: 5  type: integer
> column: 6  type: integer
> column: 7  type: integer
> column: 8  type: integer
> column: 9  type: string  length: 1
> column: 10  type: double
> column: 11  type: double
> column: 12  type: string  length: 23
> column: 13  type: integer
> column: 14  type: string  length: 10
> column: 15  type: string  length: 18
> WARNING: Column 7 defined as string has only integer values
> DBMI-DBF driver error:
> SQL parser error in statement:
> insert into adr_dbx2 values ( 900000001, 09, 1, 79, 149, 001, ,
> 10, '', 4431350.18, 5329876.12, 'Sankt-Ottilien-Straße', 82299,
> 'Türkenfeld', 'b Furstenfeldbruck')
> Error in db_execute_immediate()
> ERROR: Cannot insert values: insert into adr_dbx2 values
> ( 900000001, 09,
>        1, 79, 149, 001, , 10, '', 4431350.18, 5329876.12,
>        'Sankt-Ottilien-Straße', 82299, 'Turkenfeld', 'b
> Fürstenfeldbruck')
> The warning message regarding column 7 is irrelevant, the same error occurs
> when it is set to string.
> Question 1: Is my attempt reasonable or is the module unsuitable for the
> task ?
> Otto Dassau advised me to try v.in.db instead.
> Sorry Otto, still no luck:
> After converting the data source into a DBF-file by OpenOffice, this
> happens:
> First step:
> cp address.dbf $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/address.dbf
> Second step:
> GRASS 6.0.cvs: > v.in.db table=address.dbf y=11 x=10 cat=1 out=foo
> select 1, 10, 11 from address.dbf
> Error in db_open_select_cursor()
> ERROR: Cannot open select cursor: 'select 1, 10, 11 from address.dbf'
> Question 2: See question 1
> Can anybody please help me out?
> Thanks,
> Peter
> Dr. Peter Löwe
> Diplom-Geograph
> <loewe at geomancers.net>
> DSL Komplett von GMX +++ Supergünstig und stressfrei einsteigen!
> AKTION "Kein Einrichtungspreis" nutzen: http://www.gmx.net/de/go/dsl
