[GRASS5] [bug #2968] (grass) Re: [Pkg-grass-general] Please use libtool soname versioning
Request Tracker
grass-bugs at intevation.de
Sat Feb 5 11:32:04 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2968
On Fri, Feb 04, 2005 at 10:03:25AM -0500, Steve Halasz wrote:
> Currently the libraries are versioned like libgrass_shape.6.0.cvs.so
> with links. It would be great if you could switch to a soname versioning
> scheme a la libtool[1]. This would solve a problem with packaging
> programs that depend on the grass libs. Right now, every new release of
> grass will break the gdal-grass packages dependencies. The libgrass
> version should change based on changes to its interface rather than
> versions of grass.
> I looked into using libtool for grass and it looked like it was very
> helpful to use automake to integrate it. So are there reasons grass
> isn't using automake/libtool already?
The (non) usage of libtool has been discussed a few times in the
past, see for example:
http://grass.itc.it/pipermail/grass5/2002-April/005065.html
http://grass.itc.it/pipermail/grass5/2003-November/013059.html
> If using libtool isn't palatable,
> can we at least adopt the versioning scheme beginning at libgrass0.0.0?
Maybe yes. This should be discussed on the GRASS developers list (note
that the bug report communication is automatically forwarded to the list).
But: We'll have to find a person who is actually implementing that in
this case.
Markus
--- Headers Follow ---
>From neteler at itc.it Sat Feb 5 17:32:04 2005
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 2ECCC102BF4
for <grass-bugs at lists.intevation.de>; Sat, 5 Feb 2005 17:32:04 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id E4D813700F
for <grass-bugs at lists.intevation.de>; Sat, 5 Feb 2005 17:32:03 +0100 (CET)
Received: from mail.itc.it (ns.itc.it [217.77.80.3])
by mail.intevation.de (Postfix) with ESMTP id E960636DC6
for <grass-bugs at intevation.de>; Sat, 5 Feb 2005 17:32:01 +0100 (CET)
Received: from ntmain.itc.it ([10.0.20.40])
by mail.itc.it (8.12.11/8.12.11) with SMTP id j15GW0MV026402;
Sat, 5 Feb 2005 17:32:00 +0100
Received: from orchestra.itc.it ([10.0.10.11])
by ntmain.itc.it (SMSSMTP 4.0.4.64) with SMTP id M2005020517320001418
; Sat, 05 Feb 2005 17:32:00 +0100
Received: from thuille.itc.it. (thuille [10.40.0.110])
by orchestra.itc.it (8.12.11/8.12.11) with ESMTP id j15GW0ZR012184;
Received: from thuille.itc.it. (localhost.localdomain [127.0.0.1])
by thuille.itc.it. (8.12.11/8.12.11) with ESMTP id j15GW0DA004591;
Received: (from neteler at localhost)
by thuille.itc.it. (8.12.11/8.12.11/Submit) id j15GW09N004589;
Date: Sat, 5 Feb 2005 17:32:00 +0100
To: Steve Halasz <debian at adkgis.org>
Cc: grass-bugs at intevation.de,
DebianGIS <pkg-grass-general at lists.alioth.debian.org>
Subject: Re: [Pkg-grass-general] Please use libtool soname versioning
Message-ID: <20050205163200.GB4536 at thuille.itc.it>
Mail-Followup-To: Steve Halasz <debian at adkgis.org>,
References: <1107529405.3856.17.camel at marcy>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
In-Reply-To: <1107529405.3856.17.camel at marcy>
User-Agent: Mutt/1.4.1i
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
