[GRASS5] [bug #2968] (grass) Re: [Pkg-grass-general] Please use libtool soname versioning
    Glynn Clements
    glynn at gclements.plus.com
    Mon Feb  7 15:21:20 EST 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2968
> > If using libtool isn't palatable,
> > can we at least adopt the versioning scheme beginning at libgrass0.0.0?
> Maybe yes. This should be discussed on the GRASS developers list (note
> that the bug report communication is automatically forwarded to the list).
Implementing soname versioning (at least for Linux) is simple enough;
just add:
	-Wl,-soname,$(SONAME)
to the linking command for building shared libraries, where $(SONAME)
is the library name, e.g.:
	SONAME = $(SHLIB_PREFIX)$(SHLIB_NAME)$(SHLIB_SUFFIX).$(SHLIB_VERSION)
[SHLIB_VERSION would need to be defined in any Makefile which includes
Lib.make.]
The main problem is ensuring that developers actually increment the
version whenever they make an incompatible change (otherwise there is
no point in having versioning).
