[GRASS5] Re: 6.0.x CVS
Markus Neteler neteler at itc.it
Tue Feb 8 08:19:37 EST 2005
> > > I was thinking
> > > 	mv grass51 grass6
> > > 	ln -s grass6 grass51
> Done now!
> CVS access is reenabled.
> I switched off grass51 in the viewcvs interface to avoid=20
> showing the same module twice.=20
> I hope links will also be corrected then, because they fail.
> For fresh checkouts: Use module grass6 now.
> For old checkouts: You can continue using grass51,
> no need to do a complete recheck in at this time.
Thanks for the change. It works well.
> We could experiment with scripts changing the CVS/Root file contents.
Find attached the script doing this job.
Usage:
 1. Go to GRASS 6 CVS source code main directory, store the attached
    script there, then use 'find' to launch the script:
       cd grass6src_cvs/
       find . -name 'Repository' -exec sh change-repository.sh {} \;
 2. After that, cleanup of Repository.tmp files
       find . -name 'Repository.tmp' -exec  rm {} \;
 3. Done. Continue working as before.
Cheers
 Markus
Type: application/x-sh
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050208/82338b05/change-repository.sh
