[GRASS5] [bug #2986] (grass) v.surf.rst wrong quant
Request Tracker grass-bugs at intevation.de
Sun Feb 13 23:58:53 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2986
Subject: v.surf.rst  wrong quant
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
The quant result from query of elevation data computed by v.surf.rst (and s.surf.rst) is not correct
testquant4 in cent, quant   (326)
testquant4 in cent, actual  (327.380127)
(should be 327)
The problem may be in
lib/rst/interp_float/output2d.c
 G_quantize_fp_map_range (params->elev, mapset,
                             (DCELL) zminac - 0.5, (DCELL) zmaxac + 0.5,
                           (CELL) (zminac - 0.5), (CELL) (zmaxac + 0.5));
This bug might have been there for years. Other parameters
are quantized correctly.
Helena
-------------------------------------------- Managed by Request Tracker
