[GRASS5] fixed 2 bugs in GIS Manager GRASS 6
Michael Barton michael.barton at asu.edu
Wed Feb 16 02:16:05 EST 2005
This error is erratic. The most consistent way I've been able to reproduce
it and get v.surf.rst to work is the following:
Start GRASS
Run v.surf.rst from the menu
V.surf.rst fails
Quite GIS Manager but not GRASS
Restart GIS Manager (i.e., run d.m & from the command prompt)
V.surf.rst starts
It seems to choke on the line:
Authors: original version -  H.Mitasova, L.Mitas, I. Kosinovsky, D.P. Gerdes
See manual pages for reference and publications
This kind of output regularly causes programs called from the tcltk menus to
fail. I've futzed with it a bit and can't get it to run consistently. Can
you perhaps not have it try to display this to the xterm? It ought to run OK
then.
I went ahead and fixed the other bugs Hamish noted in the menus. I'll try to
get them committed tomorrow. I'll try to see if there is anything else I can
try with v.surf.rst.
Michael
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
> From: Helena <hmitaso at unity.ncsu.edu>
> Organization: NCSU
> Date: Tue, 15 Feb 2005 23:59:29 -0500
> To: Hamish <hamish_nospam at yahoo.com>
> Cc: Radim Blazek <blazek at itc.it>, <michael.barton at asu.edu>,
> <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] fixed 2 bugs in GIS Manager GRASS 6
> Hamish wrote:
>>>> I just fixed 2 bugs in the GIS Manager for GRASS 6 that prevented
>>>> r.terraflow and d.colors from operating via the menus. I looked on
>>>> the bugtracker system to report them fixed but either a) I was
>>>> unable to properly search for them or b) neither was reported via
>>>> the bugtracker.
>>>> I have some improvements to the GIS Manager but will hold off until
>>>> 6.0 is released. Any word on when that will be?
>>> Next week?
>> It would be nice to get v.surf.rst (2x #2990) and missing opt->key_desc
>> bugs (#3002) fixed first.
>> http://intevation.de/rt/webrt?serial_num=2990
> I could not reproduce this one - it looks like the user gave invalid
> combination of options -
> the z given both as a z-coordinate (layer=0) and as an attribute zcolumn=ELEV,
> however, I tried it with one of my data sets and it behaved correctly even
> with this mix of options
> (it either ignores zcolumn or ends with error message Vector is not 3D).
> So I am suspicious that the users data set may have a problem. If somebody can
> reproduce it
> I can try to fix it - the program ends because for a given segment it cannot
> find any points
> within the segment or its neighborhood (the segmentation may be broken).
> As for the GUI - it indeed gives an error message - Michael, is this something
> that you could fix?
> Helena
>> grass5 mailing list
>> http://grass.itc.it/mailman/listinfo/grass5
