[GRASS5] fixed 2 bugs in GIS Manager GRASS 6
Wed Feb 16 18:21:21 EST 2005
> I removed all stdout stuff from the program and it does not make a
> difference.
are you sure make ran ok & the binary updated?
I've just tested it with the fprintf("Authors:")s moved to just after the
G_parser() call. It now works (for me) from the command line->GUI, from
the d.m menus, and from the command line with options.
dmin/dmax code left in place.
display/d.m/menu.tcl is using "execute" to run v.surf.rst.
 no idea if that makes a difference.
spearfish57 dataset:
 v.surf.rst in=bugsites elev=bug.rst zcolumn=cat
[Helena: -c never needed anyway as you can do zcolumn=cat   ??
    why have a -v flag, why not just test for cvdev= option? ]
Hamish
