[GRASS5] nviz bugs?
Helena hmitaso at unity.ncsu.edu
Sun Feb 27 21:34:42 EST 2005
Bob Covill wrote:
> Hi Helena,
> I took a quick look at grass6.0 / nviz. It appears that in
> visulaization/nviz/src/draw.c "GS_draw_all_list();" has been commented
> out. This is found in the function "Ndraw_all_cmd". The legend, labels,
> and North Arrow are all handled by this function. If you un-comment it,
> The above features should be automatically re-drawn.
yes, that fixed it!
Can you please submit the change to CVS so that it is fixed
in the release too?
thank you,
Helena
> Bob
> Helena wrote:
>> I have been testing nviz using grass6 updated today and I noticed few
>> problems:
>> - label and legend do not redraw, Bob, are you around to check that,
>> it used to work
>> - nviz does not load vector points when given on command line or when
>> called
>>   from GIS manager - it gives error "no lines fileneame found...."
>>   it is possible to load the points in nviz through "vector points"
>> panel,
>>   so it is not critical, but it may be confusing to users.
>> - the mkdspf pannel should be removed - it does nothing
>> Helena
>> grass5 mailing list
>> grass5 at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass5
