[GRASS5] nviz bugs?
    Bob Covill
    bcovill at tekmap.ns.ca
    Sun Feb 27 19:17:13 EST 2005
Hi Helena,
I took a quick look at grass6.0 / nviz. It appears that in
visulaization/nviz/src/draw.c "GS_draw_all_list();" has been commented
out. This is found in the function "Ndraw_all_cmd". The legend, labels,
and North Arrow are all handled by this function. If you un-comment it,
The above features should be automatically re-drawn.
Bob
Helena wrote:
> I have been testing nviz using grass6 updated today and I noticed few
> problems:
> - label and legend do not redraw, Bob, are you around to check that, it
> used to work
> - nviz does not load vector points when given on command line or when
> called
>   from GIS manager - it gives error "no lines fileneame found...."
>   it is possible to load the points in nviz through "vector points" panel,
>   so it is not critical, but it may be confusing to users.
> - the mkdspf pannel should be removed - it does nothing
> Helena
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
