[GRASS5] d.what.rast & quantization
Markus Neteler
neteler at itc.it
Mon Feb 28 07:25:25 EST 2005
On Sun, Feb 27, 2005 at 05:19:50PM -0500, Helena wrote:
> Markus,
> is elev the result of v.surf.rst (or s.surf.rst)?
> If yes, this seems to be rst problem - Susane Rizzolli has already reported
> it.
> If you multiply the result by 1.0 in r.mapcalc, the quant is recomputed
> and the result of query is correct.
> rst calls quantize here - I did not have time to look at what quantize
> actually does and why are the min and max values done like this,
> rst was updated for FP support while FP support was still under development
> so quant might have changed and this is now producing wrong result.
> G_quantize_fp_map_range (params->elev, mapset,
> (DCELL) zminac - 0.5, (DCELL) zmaxac + 0.5,
> (CELL) (zminac - 0.5), (CELL) (zmaxac + 0.5));
> It might have been there for years, but nobody is probably using the quant
> result, so there were no compliants
Helena,
I tried to remove these 0.5 offsets, also commented the entire function call.
The results are still as indicated below (so the G_quantize_fp_map_range does
nothing?). Maybe we are looking in the wrong place?
Markus
> Markus Neteler wrote:
> >Hi,
> >looking at d.what.rast, I see output like this:
> >d.what.rast
> >Buttons
> > Left: what's here
> > Right: quit
> >278786.03515625(E) 5232741.95078125(N)
> >elev in PERMANENT, quant (447)
> >elev in PERMANENT, actual (447.190521)
> >279031.25390625(E) 5233060.73515625(N)
> >elev in PERMANENT, quant (539)
> >elev in PERMANENT, actual (540.034363)
> >278700.20859375(E) 5235660.05390625(N)
> >elev in PERMANENT, quant (-557)
> >elev in PERMANENT, actual (-558.007324)
> >The quantization rule is not obvious to me, what's the
> >background to get such results?
> >Thanks
> > Markus
> >_______________________________________________
> >grass5 mailing list
> >grass5 at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass5
