[GRASS5] [bug #3041] (grass) NVIZ max PPM dump fails when window is resized
Request Tracker grass-bugs at intevation.de
Mon Feb 28 16:03:19 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3041
Subject: NVIZ max PPM dump fails when window is resized
Grass 6.0beta2 from Debian testing
Dumping at max resolution does not work if I resize NVIZ monitor; it
produces a number of files:
-rw-r--r--   1 paolo paolo  3133457 2005-02-26 11:05 provamax2_1_1.ppm
-rw-r--r--   1 paolo paolo  3133457 2005-02-26 11:05 provamax2_1_2.ppm
-rw-r--r--   1 paolo paolo       14 2005-02-26 11:05 provamax2_1_3.ppm
-rw-r--r--   1 paolo paolo  3130385 2005-02-26 11:05 provamax2_2_1.ppm
-rw-r--r--   1 paolo paolo  3130385 2005-02-26 11:05 provamax2_2_2.ppm
-rw-r--r--   1 paolo paolo       14 2005-02-26 11:05 provamax2_2_3.ppm
-rw-r--r--   1 paolo paolo       15 2005-02-26 11:05 provamax2_3_1.ppm
-rw-r--r--   1 paolo paolo       15 2005-02-26 11:05 provamax2_3_2.ppm
-rw-r--r--   1 paolo paolo       12 2005-02-26 11:05 provamax2_3_3.ppm
-rw-r--r--   1 paolo paolo        0 2005-02-26 11:05 provamax2.ppm
-rw-r--r--   1 paolo paolo        0 2005-02-26 11:05 provamax2tmp1.ppm
-rw-r--r--   1 paolo paolo        0 2005-02-26 11:05 provamax2tmp2.ppm
-rw-r--r--   1 paolo paolo        0 2005-02-26 11:05 provamax2tmp3.ppm
Of these, the largest are cuts from the whole image.
This is the error output:
nviz elevation=t_dtm at PERMANENT
Loading Data
Update elev null mask
Loading Data
translating colors from fp
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
recalculating normals...
Row 100
Row 200
Creating PBuffer Using GLX 1.3
Create PixMap Using GLX 1.1
Final Assembled Image will be 1673 x 2048
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
Writing Tile 8 of 9
Writing Tile 9 of 9
Assembling Tiles
Destroy Pixmap and GLXPixmap
Final Assembled Image will be 2048 x 2039
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
MALLOC Failed
Writing Tile 8 of 9
MALLOC Failed
Writing Tile 9 of 9
Assembling Tiles
pnmcat: Zero byte allocation
pnmcat failed to create assembled image
Check that pnmcat is installed and path is set
pnmcat: junk in file where an integer should be
pnmcat: EOF / read error reading magic number
pnmcat failed to create assembled images
I also get an error window:
invalid command name ".dialog0.pw.f1.frame.win.text"
If it's a resize problem only, it should be easy to fix it by making the
monitor of fixed size.
Help from Bob Covill:
It appears from the output that your system could not alocate
enough memory to combine the tile images. With the max size image, a
seies of tiles are saved and then pasted together into a sinle image.
 From the files below this would be done with ...
pnmcat -lr provamax2_1_1.ppm provamax2_1_2.ppm provamax2_1_3.ppm >
provamax2tmp1.ppm
These left to right (-lr) strips are then combined into the final image.
 From the comments below it looks like pnmcat could not malloc enough
memory. If possible try combining the images on another system or with a
different (less memory intensive) software package. It would probably be
helpful in the future to add an option that allows the user to choose
the ouput image size up to the maximum allowable. The curent default is
to automatically draw the maximum allowable size the the OpenGL
configuration supports.
-------------------------------------------- Managed by Request Tracker
