[GRASS5] [bug #3042] (grass) NVIZ max PPM dump include unwanted images
Request Tracker grass-bugs at intevation.de
Mon Feb 28 16:06:52 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3042
Subject: NVIZ max PPM dump include unwanted images
Grass6.0beta2 from Debian testing.
If I switch to another window when dumping, the dump reflects the new
window instead of the NVIZ monitor. This should be made clear to the user
(a "Don't move" warning).
help from Bob Covill:
Minimize the main (visible) window before creating the off-screen context.
Because of callbacks to the main window it can sometimes replace the
off-screen context by simply moving the mouse across it. A pop-up window
would probably be helpful in this case inform
the user to first minmize the main window.
-------------------------------------------- Managed by Request Tracker
