[GRASS5] r3.mapcalc
Radim Blazek blazek at itc.it
Mon Jan 10 12:27:49 EST 2005
There were probably other bugs, but the real problem is, I believe, that
setup_region() in map3.c is not called before map_type() which is
calling G3d_openCellOld(). I think that setup_region should be
added somewhere in the beginning of r.mapcalc, but I don't want to touch
  the r.mapcalc, for now I just added setup_region() before
G3d_openCellOld().
Radim
Helena wrote:
> while testing v.vol.rst I also tried r3.mapcalc and it probably needs
> update
> due to the merge of WIND3 into WIND, it does not seem to find the
> correct value
> for depths and it is giving a fatal error - here is an example from the
> test location slovakia provided for testing of the 3D stuff
> GRASS 5.7.cvs:~/grasscvs57/grass57_exp_2003_10_18/vector/v.vol.rst >
> g.region -p3
> projection: 0 (x,y)
> zone:       0
> north:      5530000
> south:      5275000
> west:       4186000
> east:       4631000
> top:        3000.00000000
> bottom:     0.00000000
> nsres:      500
> nsres3:     500
> ewres:      500
> ewres3:     500
> tbres:      500
> rows:       510
> rows3:      510
> cols:       890
> cols3:      890
> depths:     6
> [Raster MASK present]
> r3.mapcalc "test=precip3d.500z50*1."
> FATAL ERROR: G3d_adjustRegion: depths <= 0
> Helena
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
