[GRASS5] d.m form mode
Radim Blazek
blazek at itc.it
Wed Jan 12 09:38:30 EST 2005
Florian Goessmann wrote:
> On 11.01.2005, at 16:51, Michael Barton wrote:
>> There was a check box on the vector panel of the GIS Manager to switch to
>> terminal output. I hope it is still there for those of us for whom
>> form mode
>> is broken.
> it is still there and it works. i however suggest to set this button to
> "1" by default to make the query tool button work out of the box on all
> systems.
It means that nobody will use that or even dicover that possibility and
nobody try to fix it.
Radim
> regards
>> On 1/11/05 2:03 AM, "Radim Blazek" <blazek at itc.it> wrote:
>>> I have changed default form mode for vector attributes in d.m to GUI,
>>> you change to terminal output using 'g.gisenv set=DM_FORM_MODE=txt'.
>>> Radim
>> ______________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution and Social Change
>> Arizona State University
>> Tempe, AZ 85287-2402
>> USA
>> voice: 480-965-6262; fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
>> grass5 mailing list
>> grass5 at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass5
