[GRASS5] d.m form mode
Michael Barton michael.barton at asu.edu
Wed Jan 12 09:41:38 EST 2005
I'm OK with setting it to 0 given Radim's reasons and the fact that it can
be also set in g.gisenv (and HOPE that someone can fix this).
On 1/12/05 7:38 AM, "Radim Blazek" <blazek at itc.it> wrote:
> Florian Goessmann wrote:
>> On 11.01.2005, at 16:51, Michael Barton wrote:
>>> There was a check box on the vector panel of the GIS Manager to switch to
>>> terminal output. I hope it is still there for those of us for whom
>>> form mode
>>> is broken.
>> it is still there and it works. i however suggest to set this button to
>> "1" by default to make the query tool button work out of the box on all
>> systems.
> It means that nobody will use that or even dicover that possibility and
> nobody try to fix it.
> Radim
>> regards
>>> On 1/11/05 2:03 AM, "Radim Blazek" <blazek at itc.it> wrote:
>>>> I have changed default form mode for vector attributes in d.m to GUI,
>>>> you change to terminal output using 'g.gisenv set=DM_FORM_MODE=txt'.
>>>> Radim
>>> ______________________________
>>> Michael Barton, Professor of Anthropology
>>> School of Human Evolution and Social Change
>>> Arizona State University
>>> Tempe, AZ  85287-2402
>>> USA
>>> voice: 480-965-6262; fax: 480-965-7671
>>> www: http://www.public.asu.edu/~cmbarton
>>> grass5 mailing list
>>> grass5 at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grass5
C. Michael Barton, Professor of Anthropology
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
