[GRASS5] not clear behaviour of v.clean
Radim Blazek
blazek at itc.it
Thu Jan 13 06:00:16 EST 2005
The 'thresh' is multiple, you have to give a value for each
tool: thresh=0,0,10
Radim
ivan marchesini wrote:
> Dear developpers,
> I tried to use v.clean to correct a vector map...
> if I use more than one tool at the same time, for example:
> ____________________________________________________
> v.clean input=insediamenti output=insed_prova_clean1
> tool=rmdupl,bpol,rmarea thresh=10
> I obtain the next output:
> _____________________________________________________
> WARNING: Threshold for tool 1 may not be > 0, set to 0
> | Tool | Threshold |
> | Remove duplicates | 0.000000e+00 |
> | Break polygons | 0.000000e+00 |
> | Remove small areas | 0.000000e+00 |
> Tool: Remove small areas
> Removed areas: 0
> 0 areas of total size 0 removed
> it seems that the first tool force the value of the threshold of tool
> rmarea to be 0.0
> in fact if I use v.clean over the same file but using only rmarea tool..
> the module remove 6 ares... as you can see below:
> v.clean input=insediamenti output=insed_prova_clean3 tool=rmarea
> thresh=10
> | Tool | Threshold |
> | Remove small areas | 1.000000e+01 |
> Removed areas: 11
> 11 areas of total size 24.7048 removed
> It could be a bug????
> bye
> Ivan
