[GRASS5] [bug #2925] (grass) r.resamp.rst segfault
Request Tracker grass-bugs at intevation.de
Fri Jan 21 16:41:29 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2925
Subject: r.resamp.rst segfault
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
r.resamp.rst input=dem5 elev=dem1 ew_res=1 ns_res=1
mapset for input proba
Processing all selected output files will require
239700 bytes of disk space for temp files
zmin=-7441.180302,zmax=4027.909900
Temporarily changing the region to desired resolution...
Changing the region back to initial...
Percent complete: Segmentation fault
It works perfect in 5.4. Input dem is an output of r.surf.fractal. The region is very small:
g.region -p
projection: 99 (Transverse Mercator)
zone:       0
datum:      etrs89
ellipsoid:  grs80
north:      326715
south:      326480
west:       266920
east:       267175
nsres:      5
ewres:      5
rows:       47
cols:       51
Maciek
-------------------------------------------- Managed by Request Tracker
