[GRASS5] [bug #2925] (grass) r.resamp.rst segfault
Helena hmitaso at unity.ncsu.edu
Fri Jan 21 21:25:42 EST 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2925
> Subject: r.resamp.rst segfault
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
> r.resamp.rst input=dem5 elev=dem1 ew_res=1 ns_res=1
> mapset for input proba
> Processing all selected output files will require
> 239700 bytes of disk space for temp files
> zmin=-7441.180302,zmax=4027.909900
> Temporarily changing the region to desired resolution...
> Changing the region back to initial...
> Percent complete: Segmentation fault
> It works perfect in 5.4. Input dem is an output of r.surf.fractal. The region is very small:
> g.region -p
> projection: 99 (Transverse Mercator)
> zone:       0
> datum:      etrs89
> ellipsoid:  grs80
> north:      326715
> south:      326480
> west:       266920
> east:       267175
> nsres:      5
> ewres:      5
> rows:       47
> cols:       51
> Maciek
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
It is probably related to the merge of WIND and WIND3. If you find out in the code
what needs to be changed and test it, I will submit the fix. It is probably simple.
Helena
