[GRASS5] [bug #2925] (grass) r.resamp.rst segfault
guest user via RT grass-bugs at intevation.de
Sat Jan 22 04:52:05 EST 2005
Here is a backtrace:
(gdb) r srtm.dem el=rst ew_res=10 ns_res=10
Percent complete:    0%
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 1086126496 (LWP 24161)]
0x4064995c in mallopt () from /lib/tls/libc.so.6
(gdb) bt
#0  0x4064995c in mallopt () from /lib/tls/libc.so.6
#1  0x406473fd in malloc () from /lib/tls/libc.so.6
#2  0x40517d31 in G_malloc (n=Variable "n" is not available.
) at alloc.c:23
#3  0x40542fba in G_site_new_struct (cattype=Variable "cattype" is not available.
) at sites.c:80
#4  0x4002c5d7 in IL_check_at_points_2d (params=0x804d340, data=Variable
"data" is not available.
    at point2d.c:67
#5  0x4002f8f6 in IL_resample_interp_segments_2d (params=0x804d340,
    bitmask=0x0, zmin=Variable "zmin" is not available.
) at ressegm2d.c:565
#6  0x0804af10 in main (argc=5, argv=0xbffff2a4) at main.c:573
Probably it is related to the cross validation changes.
Markus
-------------------------------------------- Managed by Request Tracker
