[GRASS5] Re: [GRASSLIST:5482] Re: file g.gisenv / clean_temp / run not found
after compilation
Force3 Team
subscription at force3-india.org
Sat Jan 22 13:53:29 EST 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Force3 Team wrote:
| Markus Neteler wrote:
~ |Hash: SHA1
~ |Hi,
~ |I am using Grass 5.4.0 for Arm Linux Handheld.
~ |I compiles the Grass And Baby Grass for arm-linux and loaded to handheld.
~ |but when i run the grass54, it ask for file g.gisenv
~ |in the grass54 bin folder.
~ |unfortunatly the files is not found after compiling ?
~ |for the native machine it work fine.
~ |So,
~ |1. Can any one tell me, how can i compile only these file for
~ |arm-linux-gcc ?
~ |2. The File grass54/etc/clean_temp
~ |3. The File grass54/etc/run
~ |are also not present.
~ | It may be possible (can't remember and away from the office
~ | machine now) that the desired modules have to be included
~ | into the babyGRASS source code.
~ | Just add the relevant directories to
~ | handheld/babyGRASS_packagingsrc.sh
~ | package and compile again.
~ | Good luck
~ | Markus
~ Dear Markus
~ Yes you are correct, I check that,
~ The modules is also there. in the sh file and when we run .configure
~ as
~ export CC=arm-linux-gcc
~ export CPP=arm-linux-c++
~ export C77=arm-linux-c77
~ CFLAGS="-I/opt/simputer/include -I/opt/simputer/arm-linux/include
~ -L/opt/simputer/lib/ -L/opt/simputer/arm-linux/lib/" CC=arm-linux-gcc &&
~ ../babyGrass_src/configure --prefix=/opt/simputer
~ --exec-prefix=/opt/simputer --build=Simputer --host=arm-linux
~ --target=arm-linux --x-includes=/opt/simputer/include/X11/
~ --x-libraries=/opt/simputer/arm-linux/lib/X11/
~ --with-gtk-prefix=/opt/simputer/gtk1.2/
~ --includedir=/opt/simputer/include/ --libdir=/opt/simputer/lib
~ --without-fftw --without-proj --with-cxx=yes --without-tiff
~ --without-tcltk --without-postgres --without-opengl --without-odbc
~ The Module folder is get copied in src\general\g.gisenv and on
~ runing make the file main.o get created in src\general\g.gisenv
~ but We will not get out the g.gisenv as excutable.
~ It give out as error in error.log
~ Compilation error in module: src/general/g.gisenv
~ There are some many other files.. on this.
~ Remeber :
~ On Native Linux 9.0 it is working 100% fine.
~ I am trying to compile it for Arm-Linux
~ TO Know:
~ Do the application need the processor for gcc only ?
~ Do this module run on only native.
~ http://www.force3-india.org/downloads/Technology/GRASS_conf_2002.pdf
~ You Can access the Error Log and Compiles srcipts as
~ http://www.force3-india.org/downloads/Grass/
~ Thanks in Advance
~ Waiting for reply.
Regards, and Have a nice day.
Prachait Saxena
Force3 Team
(M) :- +91 98229 44025
(M) :- +91 93732 81318
(E) :- prachait (at) force3-india (dot) com
(E) :- subscription (at) force3-india (dot) com
(W) :- http://www.force3-india.org/
_________________________________
Our Solution at Microsoft Solution Market Place
Public Grievance Redressal System version 1.0.0
http://www.microsoft.com/asia/solutionmarketplace/solutiondetail.asp?ind=3&sid=30101&type=1&solid=1760&language=1&searchresult=true&sLanguage=1
Checkout Latest:
http://force3-india.org/downloads/Presentations/Force3-India_inCLASS-Presentation.zip
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFB8qEpj59Y6fbuGH0RAtawAJ4zRsfg7jwvLnKv+gaS/W662GBl+wCgk+Q2
nKv+PMe4x55fmJSSu/t/gGU=
=+17x
-----END PGP SIGNATURE-----
