[GRASS5] [bug #2937] (grass) v.in.ogr, GUI, fails during "Building
areas:"
Radim Blazek
blazek at itc.it
Tue Jan 25 03:25:41 EST 2005
Could you send me the shapefile?
Radim
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2937
> Subject: v.in.ogr, GUI, fails during "Building areas:"
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
> My system: Mdk10.1, gcc 3.3.4.
> v.in.ogr works fine directly from the terminal, but fails during "Building areas:" when invoked from GUI. Then it prints to the terminal as follows:
> GRASS 6.0.cvs:~ > too many nested evaluations (infinite loop?)
> (procedure "GlobalVar::exists" line 1)
> invoked from within
> "GlobalVar::exists $_widget($path,var)"
> (procedure "ProgressBar::_modify" line 4)
> invoked from within
> "ProgressBar::_modify .dialog0.progress"
> ("eval" body line 1)
> invoked from within
> "eval ProgressBar::$cmd .dialog0.progress $args"
> (procedure ".dialog0.progress" line 1)
> invoked from within
> "$opt($dlg,progress) _modify"
> (procedure "progress" line 7)
> invoked from within
> "progress $dlg $val"
> invoked from within
> "if [eof $fh] {
> close $fh
> } else {
> set str [gets $fh]
> append str "\n"
> if { [fblocked $fh] } { set str [read $fh] }
> while {[set idx [string f..."
> (procedure "prnout" line 5)
> invoked from within
> "prnout 1 file6"
> GRASS 6.0.cvs:~ >
> Here goes the message displayed in the GUI widnow during import, prior to failure:
> v.in.ogr dsn=/home/maciek/polska_shp/granica92/granica.shp output=granice min_area=0.0001 snap=-1
> A datum name etrs89 (European_Terrestrial_Reference_System_1989) was specified without transformation parameters.
> Note that the GRASS default for etrs89 is towgs84=0.000,0.000,0.000.
> Projection of input dataset and current location appear to match.
> Proceeding with import...
> Layer: granica
> Building topology ...
> Registering lines:
> 43 primitives registered
> Building areas:
> 41 areas built
> 41 isles built
> Attaching islands:
> Attaching centroids:
> Topology was built.
> Number of nodes : 42
> Number of primitives: 43
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 43
> Number of centroids : 0
> Number of areas : 41
> Number of isles : 41
> Number of incorrect boundaries : 2
> Number of areas without centroid : 41
> Cleaning polygons, result is not guaranteed!
> Topology was built.
> Number of lines : 0
> Number of areas : -
> Number of isles : -
> Break polygons:
> Registering points ... 3154
> All points (vertices): 5033
> Registered points (unique coordinates): 3154
> Points marked for break: 81
> Breaks: 0
> Breaks: 30
> Breaks: 47
> Breaks: 74
> Breaks: 108
> Breaks: 143
> Remove duplicates:
> Duplicates: 0
> Duplicates: 1
> Duplicates: 2
> Duplicates: 3
> Duplicates: 4
> Duplicates: 5
> Duplicates: 6
> Duplicates: 7
> Duplicates: 8
> Duplicates: 9
> Duplicates: 10
> Duplicates: 11
> Duplicates: 12
> Duplicates: 13
> Duplicates: 14
> Duplicates: 15
> Duplicates: 16
> Duplicates: 17
> Duplicates: 18
> Duplicates: 19
> Duplicates: 20
> Duplicates: 21
> Duplicates: 22
> Duplicates: 23
> Duplicates: 24
> Duplicates: 25
> Duplicates: 26
> Duplicates: 27
> Duplicates: 28
> Duplicates: 29
> Duplicates: 30
> Duplicates: 31
> Duplicates: 32
> Duplicates: 33
> Duplicates: 34
> Duplicates: 35
> Duplicates: 36
> Duplicates: 37
> Duplicates: 38
> Duplicates: 39
> Duplicates: 40
> Duplicates: 41
> Duplicates: 42
> Duplicates: 43
> Duplicates: 44
> Duplicates: 45
> Duplicates: 46
> Duplicates: 47
> Duplicates: 48
> Duplicates: 49
> Duplicates: 50
> Duplicates: 51
> Duplicates: 52
> Duplicates: 53
> Duplicates: 54
> Duplicates: 55
> Duplicates: 56
> Break boundaries:
> Intersections: 0
> Intersections: 0
> Remove duplicates:
> Duplicates: 0
> Clean boundaries at nodes:
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Modifications: 0
> Change dangles to lines:
> Removed dangles: 0 removed lines: 0
> Remove bridges:
> Removed bridges: 0 removed lines: 0
> Building areas:
> 43 areas built
> 19 isles built
> Attaching islands:
> Topology was built.
> Number of nodes : 81
> Number of primitives: 186
> Number of lines : 0
> Number of boundaries: 186
> Number of areas : 43
> Number of isles : 19
> Number of areas without centroid : 43
> Layer: granica
> Registering lines:
> 148 primitives registered
> Building areas:
> Maciek
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
