[GRASS5] [bug #2937] (grass) v.in.ogr, GUI, fails during "Building areas:"
Request Tracker
grass-bugs at intevation.de
Mon Jan 24 17:54:28 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2937
Subject: v.in.ogr, GUI, fails during "Building areas:"
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
My system: Mdk10.1, gcc 3.3.4.
v.in.ogr works fine directly from the terminal, but fails during "Building areas:" when invoked from GUI. Then it prints to the terminal as follows:
GRASS 6.0.cvs:~ > too many nested evaluations (infinite loop?)
(procedure "GlobalVar::exists" line 1)
invoked from within
"GlobalVar::exists $_widget($path,var)"
(procedure "ProgressBar::_modify" line 4)
invoked from within
"ProgressBar::_modify .dialog0.progress"
("eval" body line 1)
invoked from within
"eval ProgressBar::$cmd .dialog0.progress $args"
(procedure ".dialog0.progress" line 1)
invoked from within
"$opt($dlg,progress) _modify"
(procedure "progress" line 7)
invoked from within
"progress $dlg $val"
invoked from within
"if [eof $fh] {
close $fh
} else {
set str [gets $fh]
append str "\n"
if { [fblocked $fh] } { set str [read $fh] }
while {[set idx [string f..."
(procedure "prnout" line 5)
invoked from within
"prnout 1 file6"
GRASS 6.0.cvs:~ >
Here goes the message displayed in the GUI widnow during import, prior to failure:
v.in.ogr dsn=/home/maciek/polska_shp/granica92/granica.shp output=granice min_area=0.0001 snap=-1
A datum name etrs89 (European_Terrestrial_Reference_System_1989) was specified without transformation parameters.
Note that the GRASS default for etrs89 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: granica
Building topology ...
Registering lines:
43 primitives registered
Building areas:
41 areas built
41 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes : 42
Number of primitives: 43
Number of points : 0
Number of lines : 0
Number of boundaries: 43
Number of centroids : 0
Number of areas : 41
Number of isles : 41
Number of incorrect boundaries : 2
Number of areas without centroid : 41
Cleaning polygons, result is not guaranteed!
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points ... 3154
All points (vertices): 5033
Registered points (unique coordinates): 3154
Points marked for break: 81
Breaks: 0
Breaks: 30
Breaks: 47
Breaks: 74
Breaks: 108
Breaks: 143
Remove duplicates:
Duplicates: 0
Duplicates: 1
Duplicates: 2
Duplicates: 3
Duplicates: 4
Duplicates: 5
Duplicates: 6
Duplicates: 7
Duplicates: 8
Duplicates: 9
Duplicates: 10
Duplicates: 11
Duplicates: 12
Duplicates: 13
Duplicates: 14
Duplicates: 15
Duplicates: 16
Duplicates: 17
Duplicates: 18
Duplicates: 19
Duplicates: 20
Duplicates: 21
Duplicates: 22
Duplicates: 23
Duplicates: 24
Duplicates: 25
Duplicates: 26
Duplicates: 27
Duplicates: 28
Duplicates: 29
Duplicates: 30
Duplicates: 31
Duplicates: 32
Duplicates: 33
Duplicates: 34
Duplicates: 35
Duplicates: 36
Duplicates: 37
Duplicates: 38
Duplicates: 39
Duplicates: 40
Duplicates: 41
Duplicates: 42
Duplicates: 43
Duplicates: 44
Duplicates: 45
Duplicates: 46
Duplicates: 47
Duplicates: 48
Duplicates: 49
Duplicates: 50
Duplicates: 51
Duplicates: 52
Duplicates: 53
Duplicates: 54
Duplicates: 55
Duplicates: 56
Break boundaries:
Intersections: 0
Intersections: 0
Remove duplicates:
Duplicates: 0
Clean boundaries at nodes:
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Change dangles to lines:
Removed dangles: 0 removed lines: 0
Remove bridges:
Removed bridges: 0 removed lines: 0
Building areas:
43 areas built
19 isles built
Attaching islands:
Topology was built.
Number of nodes : 81
Number of primitives: 186
Number of lines : 0
Number of boundaries: 186
Number of areas : 43
Number of isles : 19
Number of areas without centroid : 43
Layer: granica
Registering lines:
148 primitives registered
Building areas:
Maciek
-------------------------------------------- Managed by Request Tracker
