[GRASS5] Re: [STATSGRASS] kriging, R and GRASS
Roger Bivand
Roger.Bivand at nhh.no
Tue Jan 25 12:22:21 EST 2005
On Wed, 19 Jan 2005, Glynn Clements wrote:
> Roger Bivand wrote:
> > > > On Mon, 17 Jan 2005, Roger Bivand wrote:
> > > > ... and also wanted show that rastput() would scale well to much finer
> > > > grids - which it does - and found a bug in rastput() and other functions
> > > > that has led to the layer being written to the GRASS database with the
> > > > wrong window if system("g.region ... ") is used. This is the same bug that
> > > > affected gmeta() until Bodo Ahrens found it 18 months ago. The problem was
> > > > that the GRASS library function tries to be too clever (I think disk
> > > > access was very slow when it was written), and stores a local version of
> > > > the data in memory in a cache of sorts. It does not check, though, whether
> > > > the data on disk have changed - it just returns the cached values! Using a
> > > > lower-level function, and conditionally altering G__init_window () seems
> > > > to have fixed it. The new version should reach CRAN soon.
> > > Roger,
> > > is there any change which should go into GRASS-CVS?
> > G__init_window () in src/libes/gis/window_map.c does the same as in my
> > local copy, that is calls G_get_window (), rather than G__get_window ().
> > What usually causes trouble for non-exiting use of libgis.a is the number
> > of places things are saved in a global variable (like G__.) which do not
> > get refreshed when the data on disk change. You can see it happening in
> > G_get_window () and its use of static int first (get_window.c), which uses
> > the cached dbwindow without checking the disk version write time. My guess
> > would be that I don't loose much in time by doing G__get_window () always,
> > but this time I hadn't realised that G__init_window () called in opening
> > and closing cells imposes the stale header, from G_get_window ().
> > Is checking the write time faster than just reading the current window? If
> > so, G_get_window () could be altered to record its last refresh time, and
> > if the window had been written since then, re-read. If not, G_get_window ()
> > should just read anyway. How would this play when the GRASS database is
> > across a network?
> G_get_window() shouldn't be re-reading the WIND file. For the vast
> majority of programs, it's essential that repeated calls to
> G_get_window() always return the same data.
> Changing it for the benefit of a long-running program will break
> normal programs.
> If you need to force a re-read, add a new function which clears the
> G__.window_set flag, so that a subsequent call to G_get_window() will
> re-read the WIND file.
> That will ensure that existing code doesn't break if the WIND file
> changes during execution.
Thanks. I'm reviewing my code against the 6.0.0beta lib/gis to see how
some small functions like this that the R interface needs could be merged
back. Something like this could be put in unconditionally too.
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
