[GRASS5] [bug #2927] (grass) d.what.vect - broken pipe
Radim Blazek
blazek at itc.it
Thu Jan 27 07:48:29 EST 2005
I have got an idea! main() in lib/form/form.c is using G_* functions and
G_gisinit() should be always called before other G_ functions are used.
Could you please try to comment sleep(1) and add G_gisinit("form");
as the first function in main(), i.e. before
G_debug ( 2, "Form: main()" ); ?
Let us know if it helps.
Radim
Maciek Sieczka wrote:
> From: "Hamish" <hamish_nospam at yahoo.com>
>> + sleep(1);
>>> Unless this breaks something, can we apply it so that all systems can
>>> use the form mode?
>> when tried in the past this made response time horrible.
> I tried the "sleep(1)" patch and it did the trick on Mandrake 10.1. As
> expected the response time is 1 second worse for each feature, but only for
> the *first* query. Each following query result pops up in a reasonable,
> standard pace. Expected too?
> Also thanks to this "patch" v.digit became more usable - now the atribute
> table pops up automatically when a new feature is digitized and at last it
> is possible to edit the atributes table without having to click dozens of
> times which was the case so far. Again, each first call is 1 delayed
> second,
> each next on normal pace - until the attribute window is closed.
> I don't think it's a good idea to apply it into CVS for good as it is not a
> real solution, but on the other hand it would be very practical if Debian,
> Mandrake 10 and 10.1 users could be somehow informed that such a dirty
> workaround is possible temporarily. How can this be done?
> Anyway, does anybody have an idea what the hack that on e.g. Mandrake 9.2
> this strange patch is not necessary? And also why does this bug attack less
> frequently on Grass57 (exp_2004_12_18) than on Grass60 on my Mdk 10.1?
> Maciek
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
