[GRASS5] [bug #2936] (grass) d.barscale doesn't work
Harmish Bowman via RT grass-bugs at intevation.de
Sun Jan 30 23:54:47 EST 2005
> >> GRASS 6.0.cvs:~ > d.barscale -m
> >> unable to open panel  No such file or directory
> > Are you sure that "unable to open panel  No such file or directory"
> > is exact? I can't find that error message.
> Yes, it is an EXACT copy/paste from the terminal output.
The only "unable to open panel" I could find was in
display/drivers/XDRIVER/XDRIVER24/Panel.c, but that is always "unable to open
panel file".
> > does running:
> > g.tempfile pid=$$
> > seem to work correctly?
>  After running g.tempfile pid=$$ I get:
>  /home/grassdata/caves92/PERMANENT/.tmp/localhost/3219.0
>  Is that what it should be?
Yes, I wanted to check if your temporary directory was writeable.
Seems to be ok.
Do you see the same problem if you try from a newly created location & mapset?
Hamish
-------------------------------------------- Managed by Request Tracker
