[GRASS5] Re: [bug #2936] (grass) d.barscale doesn't work
Maciek Sieczka
werchowyna at pf.pl
Mon Jan 31 06:39:45 EST 2005
From: "Harmish Bowman via RT" <grass-bugs at intevation.de>
>> >> GRASS 6.0.cvs:~ > d.barscale -m
>> >> unable to open panel No such file or directory
>> > Are you sure that "unable to open panel No such file or directory"
>> > is exact? I can't find that error message.
>> Yes, it is an EXACT copy/paste from the terminal output.
> The only "unable to open panel" I could find was in
> display/drivers/XDRIVER/XDRIVER24/Panel.c, but that is always "unable to
> open
> panel file".
Forgive me Hamish, you are right. It should be "unable to open panel file:
No such file or directory" like you say.
My finger had to slip when coping/pasting then.
>> > does running:
>> > g.tempfile pid=$$
>> > seem to work correctly?
>> After running g.tempfile pid=$$ I get:
>> /home/grassdata/caves92/PERMANENT/.tmp/localhost/3219.0
>> Is that what it should be?
> Yes, I wanted to check if your temporary directory was writeable.
> Seems to be ok.
> Do you see the same problem if you try from a newly created location &
> mapset?
Yes - but only if creating a new location from EPSG code! And this way I
found the reson that d.barscale doesn't work: the PROJ_INFO file syntax is
different when a location is set up via the Grass interface and when
automatically generated from EPSG code. See this:
Via Grass set up:
unit: meter
units: meters
meters: 1.0
Automatic, from EPSG 2180:
unit: metre
units: metres
meter: 1
After replacing the automatic one with the Grass one d.barscale works fine.
Could there be any more commands which don't like the EPSG-generated
PROJ_INFO files?
Maciek
