[GRASS5] Commit sql parser patch, please
Glynn Clements
glynn at gclements.plus.com
Fri Jul 1 13:54:44 EDT 2005
Daniel Calvelo Aros wrote:
> Could anyone with CVS write acces commit Glynn's latest patch for the sql
> parser? Paul? Glynn? I attach it here so you don't have to seek through past
> emails.
Done.
> Even if it were not perfect, it's still a right step in debugging the current
> broken parser, isn't it?
What's still wrong with the parsing?
The issue of only being able to use constants on the RHS of SET
clauses is a limitation of the DBF driver.
