[GRASS5] GRASS 6.0.1 release schedule
Paul Kelly paul-grass at stjohnspoint.co.uk
Sat Jul 2 11:38:15 EDT 2005
On Sat, 2 Jul 2005, Maciek Sieczka wrote:
>>> cs2cs doesn't see GRASS's NTv2 grid files. see:
>>>   http://bugzilla.remotesensing.org/show_bug.cgi?id=834
>> Fixed by Paul. I have lightly tested; don't know if it has been applied
>> to the 6.0.x release branch.
It hasn't. I hesitated to do it because it changes the output of
"g.proj -jf" to make it machine-specific (path to gridshift files
hard-coded) and someone may be relying on the old behaviour so it may not
be a good idea to change it. But when I think about it more, the old
behaviour often didn't work so maybe it could be justified to merge the
patch.
> r.proj works ONLY when source and target mapset names are identical
> http://intevation.de/rt/webrt?serial_num=3362&display=History
That has been fixed (revert change to lib/gis/asprintf.c using G_tempfile)
I didn't resolve the bug report as there was a discussion about
G_tempfile() usage ongoing.
> d.where -l is giving wrong results
> http://intevation.de/rt/webrt?serial_num=3172&display=History
> (Paul said it shouldn't be hard to fix yet the discussion stopped at some
> point. Quite important - GIS should handle any coordinates conversion
> perfect.)
I've looked into this a bit more but still haven't been able to track it
down. See comment to bug report CCed to grass5 list.
> zooming in v.digit changes resolution in region settings
> http://intevation.de/rt/webrt?serial_num=2962&display=History
Just a little comment that I think it is a nice feature that v.digit shares
the region with the location rather than the 5.x and earlier v.digit which
by default used the region in the header of the vector map. But obviously
more thought needs to go into how the location region and the map region
interact and I don't use v.digit any more so am unable to contribute.
> r.info displays the '(zone 0)' message in any location
> http://intevation.de/rt/webrt?serial_num=3054&display=History
> (A lot mess there, sorry! Go to the bottom of the page, there is a fresh
> comment by me).
I suppose that dates back to when UTM was the only projection GRASS
supported and thus zone was always relevant. I wouldn't like to try fixing
it without risking breaking something else. It is a harmless "feature", is
it not?
