[GRASS5] Re: [GRASSLIST:7386] ANOUNCEMENT: GRASS 6 Exension Manager
benducke at compuserve.de
Mon Jul 4 09:10:00 EDT 2005
OK. I browed the net and apparently there IS a problem
with Apple's version of the dirent.h system include file.
It seems there is an easy way to fix this, though.
Try the following:
In reg_entries.c (the file that throws the error by including
an erroneous dirent.h) add a line
#include <sys/types.h>
BEFORE the line that reads:
#include </usr/include/sys/dirent.h>
This should import the necessary type definitions, which Apple
seems to have overlooked.
Now, run
make clean
then
make
to see how far the compilation gets this time. If it stops at another
file with the same error message, apply the same fix to that file as
well.
Hope this helps
Benjamin
----- Originalnachricht -----
Von: Michael Barton <michael.barton at asu.edu>
Datum: Sonntag, 3. Juli 2005 6:57 pm
Betreff: Re: [GRASSLIST:7386] ANOUNCEMENT: GRASS 6 Exension Manager
> Benjamin,
> I'm very excited about GEM. I just got back from Valencia and
> tried to
> compile it. I'm on a Mac, using Lorenzo Moretti's binaries. I did
> nothingspecial to see what happens. Here is the result.
> So I have to do a bit more to get this to compile. Any suggestions?
> Best regards
> Michael
> cmb-powerbook:/downloads/gem-0.9 cmbarton$ make
> gcc -c at_exit_funcs.c -Wall
> gcc -c error.c -Wall
> gcc -c tools.c -Wall
> gcc -c reg_deps.c -Wall
> gcc -c reg_entries.c -Wall
> /usr/include/sys/dirent.h:73: undefined type, found `u_int32_t'
> /usr/include/sys/dirent.h:74: undefined type, found `u_int16_t'
> /usr/include/sys/dirent.h:75: undefined type, found `u_int8_t'
> /usr/include/sys/dirent.h:76: undefined type, found `u_int8_t'
> cpp-precomp: warning: errors during smart preprocessing, retrying
> in basic
> mode
> In file included from /usr/include/dirent.h:64,
> from reg_entries.c:25:
> /usr/include/sys/dirent.h:73: parse error before "u_int32_t"
> /usr/include/sys/dirent.h:75: parse error before "d_type"
> /usr/include/sys/dirent.h:76: parse error before "d_namlen"
> /usr/include/sys/dirent.h:83: parse error before '}' token
> reg_entries.c: In function `restore_entries_gisman':
> reg_entries.c:614: dereferencing pointer to incomplete type
> reg_entries.c:616: dereferencing pointer to incomplete type
> reg_entries.c:666: dereferencing pointer to incomplete type
> reg_entries.c:667: dereferencing pointer to incomplete type
> make: *** [reg_entries.o] Error 1
> On 6/30/05 6:21 AM, "benducke at compuserve.de"
> <benducke at compuserve.de> wrote:
> > Sorry for the delay, everyone but I was tied up with other
> things ...
> > I just managed to wrap up a beta version of the GRASS Extensions
> > Manager, as announced in the latest GRASS Newsletter.
> > I am also providing a small sample extension consisting of an
> overhauled> cumulative viewshed analysis module and another one to
> calculate a
> > prominence index.
> > Please excuse the poor state of the documentation. I am working
> on it,
> > but field season will start soon, so don't expect too much
> before autumn.
> > You can download the files from my (German) homepage:
> > http://www.uni-kiel.de/ufg/ufg_BerDucke.htm
> > It's the two links at the bottom of the main text frame.
> > gem-0.9.tgz is the C source code for the extensions manager plus
> > some documentation and a Linux libc2.3 executable.
> > cva.tgz is the cumulative viewshed extension.
> > If you downloaded and compiled gem, you can try the following from
> > inside a GRASS session:
> > gem http://www.uni-kiel.de/ufg/dateienDucke/cva.tgz
> > This should download the extension including HTML docs and
> > GIS Manager entries. If you restart GIS Manager, you should
> > find a new 'Xtns' menu. HTML docs are accessible from the
> > main GRASS index.html.
> > Please look for more info in the README file and let me know
> > how it works for you. I would be thankful if someone could
> > compile and try this program on MacOS X and CygWin as I do not
> > have access to such a system right now.
> > Cheers,
> > Benjamin
> ____________________
> C. Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> PO Box 872402
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
