[GRASS5] Re: [GRASSLIST:7386] ANOUNCEMENT: GRASS 6 Exension Manager
Michael Barton michael.barton at asu.edu
Tue Jul 5 10:31:40 EDT 2005
Benjamin,
I tried your suggestion and got a bit further. However, now I have a
different error. Also, FWIW, the line in my reg_entries.c does not have a
complete path. That is,
#include <dirent.h>
Instead of
#include </usr/include/sys/dirent.h>
I can't see that this is making a difference, (I tried it both ways) but
can't say for sure.
Anyway, this is the new error:
cmb-powerbook:/downloads/gem-0.9 cmbarton$ make clean
rm -f *.o *.bak core *~ gem
gcc  -c at_exit_funcs.c -Wall
gcc  -c error.c -Wall
gcc  -c tools.c -Wall
gcc  -c reg_deps.c -Wall
gcc  -c reg_entries.c -Wall
gcc  -c reg_html.c -Wall
gcc  -c actions.c -Wall
gcc  -c main.c -Wall
gcc  at_exit_funcs.o error.o tools.o reg_deps.o reg_entries.o reg_html.o
actions.o main.o -o gem -Wall
ld: can't locate file for: -lcrt1.o
make: *** [default] Error 1
This seems different from the prior error, so I haven't tried adding the
#include <sys/types.h> line. (Also, given the different error, I'm not sure
what file I'd add it to).
Michael
On 7/4/05 6:10 AM, "benducke at compuserve.de" <benducke at compuserve.de> wrote:
> OK. I browed the net and apparently there IS a problem
> with Apple's version of the dirent.h system include file.
> It seems there is an easy way to fix this, though.
> Try the following:
> In reg_entries.c (the file that throws the error by including
> an erroneous dirent.h) add a line
> BEFORE the line that reads:
> This should import the necessary type definitions, which Apple
> seems to have overlooked.
> Now, run
> make clean
> then
> make
> to see how far the compilation gets this time. If it stops at another
> file with the same error message, apply the same fix to that file as
> well.
> Hope this helps
> Benjamin
> ----- Originalnachricht -----
> Von: Michael Barton <michael.barton at asu.edu>
> Datum: Sonntag, 3. Juli 2005 6:57 pm
> Betreff: Re: [GRASSLIST:7386] ANOUNCEMENT: GRASS 6 Exension Manager
>> Benjamin,
>> I'm very excited about GEM. I just got back from Valencia and
>> tried to
>> compile it. I'm on a Mac, using Lorenzo Moretti's binaries. I did
>> nothingspecial to see what happens. Here is the result.
>> So I have to do a bit more to get this to compile. Any suggestions?
>> Best regards
>> Michael
>> /usr/include/sys/dirent.h:73: undefined type, found `u_int32_t'
>> /usr/include/sys/dirent.h:74: undefined type, found `u_int16_t'
>> /usr/include/sys/dirent.h:75: undefined type, found `u_int8_t'
>> /usr/include/sys/dirent.h:76: undefined type, found `u_int8_t'
>> cpp-precomp: warning: errors during smart preprocessing, retrying
>> in basic
>> mode
>> In file included from /usr/include/dirent.h:64,
>>                 from reg_entries.c:25:
>> /usr/include/sys/dirent.h:73: parse error before "u_int32_t"
>> /usr/include/sys/dirent.h:75: parse error before "d_type"
>> /usr/include/sys/dirent.h:76: parse error before "d_namlen"
>> /usr/include/sys/dirent.h:83: parse error before '}' token
>> reg_entries.c: In function `restore_entries_gisman':
>> reg_entries.c:614: dereferencing pointer to incomplete type
>> reg_entries.c:616: dereferencing pointer to incomplete type
>> reg_entries.c:666: dereferencing pointer to incomplete type
>> reg_entries.c:667: dereferencing pointer to incomplete type
>> make: *** [reg_entries.o] Error 1
>> On 6/30/05 6:21 AM, "benducke at compuserve.de"
>>> Sorry for the delay, everyone but I was tied up with other
>> things ...
>>> I just managed to wrap up a beta version of the GRASS Extensions
>>> Manager, as announced in the latest GRASS Newsletter.
>>> I am also providing a small sample extension consisting of an
>> overhauled> cumulative viewshed analysis module and another one to
>> calculate a
>>> prominence index.
>>> Please excuse the poor state of the documentation. I am working
>> on it,
>>> but field season will start soon, so don't expect too much
>> before autumn.
>>> You can download the files from my (German) homepage:
>>> http://www.uni-kiel.de/ufg/ufg_BerDucke.htm
>>> It's the two links at the bottom of the main text frame.
>>> gem-0.9.tgz is the C source code for the extensions manager plus
>>> some documentation and a Linux libc2.3 executable.
>>> cva.tgz is the cumulative viewshed extension.
>>> If you downloaded and compiled gem, you can try the following from
>>> inside a GRASS session:
>>> gem http://www.uni-kiel.de/ufg/dateienDucke/cva.tgz
>>> This should download the extension including HTML docs and
>>> GIS Manager entries. If you restart GIS Manager, you should
>>> find a new 'Xtns' menu. HTML docs are accessible from the
>>> main GRASS index.html.
>>> Please look for more info in the README file and let me know
>>> how it works for you. I would be thankful if someone could
>>> compile and try this program on MacOS X and CygWin as I do not
>>> have access to such a system right now.
>>> Cheers,
>>> Benjamin
>> ____________________
>> C. Michael Barton, Professor of Anthropology
>> School of Human Evolution and Social Change
>> PO Box 872402
>> Arizona State University
>> Tempe, AZ  85287-2402
>> USA
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> www: <www.public.asu.edu/~cmbarton>
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
