[GRASS5] GRASS 6.0.1 release question
Markus Neteler
neteler at itc.it
Mon Jul 4 16:26:27 EDT 2005
On Mon, Jul 04, 2005 at 07:14:49PM +0200, Paolo Cavallini wrote:
> Debian testing:
> /paolo# apt-cache policy gcc
> gcc:
> Installato: 4:3.3.5-3
> Candidato: 4:3.3.5-3
> Tabella Versione:
> *** 4:3.3.5-3 0
> 500 http://192.168.0.10 testing/main Packages
> 100 /var/lib/dpkg/status
Well, I still think that it is a good idea to get the current
code published. Changes for gcc4 are quite intrusive (correct me
if I am wrong), are not yet finished, not tested completely etc.
There is a possibility to publish 6.0.2 for that.
However, if the majority prefers to wait, then we can do that
of course. Sorry then for the people using 6.0.0...
Markus
> At 18:02, lunedì 04 luglio 2005, Markus Neteler has probably written:
> > > e.g. "GRASS does not compile with gcc 4.0" is a critical fix.
> > Is it really critical for 6.0.1? Which distro comes with gcc4?
> > Since it's half done only for 6.1, I suggest to postpone it
> > for 6.0.2 so that we have time for testing.
> > Let's not wait with 6.0.1 release.
> Paolo Cavallini
> cavallini at faunalia.it www.faunalia.it www.faunalia.com
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
