[GRASS5] Commit sql parser patch, please
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Jul 4 17:21:58 EDT 2005
Glynn Clements wrote:
> Daniel Calvelo Aros wrote:
>>Could anyone with CVS write acces commit Glynn's latest patch for the sql
>>parser? Paul? Glynn? I attach it here so you don't have to seek through past
>>emails.
> Done.
The change to the Makefile (see below) seems to stop y.tab.h being
generated (on Cygwin anyway, and compilation then fails in that
directory). No idea why.
Index: Makefile
RCS file: /grassrepository/grass51/lib/db/sqlp/Makefile,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- Makefile 19 May 2004 14:02:05 -0000 1.5
+++ Makefile 1 Jul 2005 17:51:34 -0000 1.6
@@ -16,10 +16,10 @@
default: lib
$(MKDIR) $(GISBASE)/docs/html
$(INSTALL) -m 644 description.html $(GISBASE)/docs/html/sql.html
-y.tab.c: yac.y
+y.tab.c y.tab.h: yac.y
$(YACC) -d -v yac.y
-lex.yy.c: lex.l y.tab.c
+lex.yy.c: lex.l
$(LEX) lex.l
