[GRASS5] v.in.ascii
    Hamish
    hamish_nospam at yahoo.com
    Mon Jul  4 23:11:14 EDT 2005
> > > i.e. either build topology for points or don't. "-b" and two
> > > levels of point data maps is confusing.
> > I agree. What about "if only points in the map, then no topology"?
> Anyway, we cannot change default behaviour in 6.x, that would break
> existing scripts and applications.
If points do not use topology, how could not building topology for
points-only vectors break existing scripts or applications?
Some modules might need to be adjusted, but wouldn't the user be
presented with the same thing at the both data & functionality levels
either way?
Hamish
