[GRASS5] r.wavelet
Andrea Antonello moovida at katamail.com
Thu Jul 21 03:43:52 EDT 2005
Hy Sajith,
> Andrea,
>    I tried to compile r.wavelet, with the make file you provided.
> What does the include head.mk and tail.mk means?
> Anyway I endup with some error. Error is
>            "Makefile:13: *** missing separator.  Stop."
> (I dont have idea about makefiles)
> Can you send me the complete make file.
Glynn had warned us :)
> [snip]
> For 5.x, you should write a Gmakefile, and let the "make makefiles"
> stage generate the makefile, rather than trying to write the makefile
> by hand.
My Gmakefile is the following:
PGM1=r.biowave.dec
PGM2=r.owave.dec
PGM3=r.biowave.rec
PGM4=r.owave.rec
OBJ1=biowave2.o biofunctions.o sconvolve.o
OBJ2=owave2.o biofunctions.o sconvolve.o
OBJ3=ibiowave2.o biofunctions.o sconvolve.o
OBJ4=iowave2.o biofunctions.o sconvolve.o
all: $(BIN)/$(PGM1) $(BIN)/$(PGM2) $(BIN)/$(PGM3) $(BIN)/$(PGM4)
$(BIN)/$(PGM1):$(OBJ1) $(GISLIB)
 $(CC) $(LDFLAGS) -o $@ $(OBJ1) $(GISLIB) $(MATHLIB) $(XDRLIB) $(RASTERLIB)
$(BIN)/$(PGM2):$(OBJ2) $(GISLIB)
 $(CC) $(LDFLAGS) -o $@ $(OBJ2) $(GISLIB) $(MATHLIB) $(XDRLIB) $(RASTERLIB)
$(BIN)/$(PGM3):$(OBJ3) $(GISLIB)
 $(CC) $(LDFLAGS) -o $@ $(OBJ3) $(GISLIB) $(MATHLIB) $(XDRLIB) $(RASTERLIB)
$(BIN)/$(PGM4):$(OBJ4) $(GISLIB)
 $(CC) $(LDFLAGS) -o $@ $(OBJ4) $(GISLIB) $(MATHLIB) $(XDRLIB) $(RASTERLIB)
$(OBJ1):biowave2.h
$(OBJ2):biowave2.h
$(OBJ3):biowave2.h
$(OBJ4):biowave2.h
$(GISLIB):
I never used the "make makefiles" part. How to define the "makefiles" target?
Can someone help me?
> It will be helpful if you update the r.wavelet file in grass adons,
yes, I will do that as soon as the makefile stuff is done.
> so that it can be straightly complied in grass6.
> A binary distribution is also desired, if possible.........
I have binaries for suse 9.3 and kubuntu.
But I guess they should not stay on the addons site.
I will think where to put them.
Cheers,
Andrea
> Thanks.......
> Bye
> On 7/5/05, Sajith VK <sajithvk at gmail.com> wrote:
> > Thanks Andrea,
> > For the prompt and detailed reply.
> > I will test the module after two-three days.
> > I will let you know the details.
> > (And I may trouble you with more querries!!)
> > I think we need to develop some applications using
> > this wavelet module.(Like image fusion). People
> > way not require this module directly. But wavelet
> > transformation is a good tool for may remote sensing
> > analysis.
> > Sajith VK
> > "Freedom is not free"
> > On 7/4/05, Andrea Antonello <moovida at katamail.com> wrote:
> > > Alright, I did some check and will answer and correct myself.
> > > > Yes, I simply included the r.wavelet folder in my raster folder and
> > > > everything works.
> > > Not true, you will need a file makefile with the following in it:
> > > include head.mk
> > > PGM1=r.biowave.dec
> > > PGM2=r.owave.dec
> > > PGM3=r.biowave.rec
> > > PGM4=r.owave.rec
> > > OBJ1=$(OBJARCH)/biowave2.o $(OBJARCH)/biofunctions.o
> > > $(OBJARCH)/sconvolve.o OBJ2=$(OBJARCH)/owave2.o
> > > $(OBJARCH)/biofunctions.o $(OBJARCH)/sconvolve.o
> > > OBJ3=$(OBJARCH)/ibiowave2.o $(OBJARCH)/biofunctions.o
> > > $(OBJARCH)/sconvolve.o OBJ4=$(OBJARCH)/iowave2.o
> > > $(OBJARCH)/biofunctions.o $(OBJARCH)/sconvolve.o all: $(BIN)/$(PGM1)
> > > $(RASTERLIB) $(BIN)/$(PGM2):$(OBJ2) $(GISLIB)
> > > $(RASTERLIB) $(BIN)/$(PGM3):$(OBJ3) $(GISLIB)
> > > $(RASTERLIB) $(BIN)/$(PGM4):$(OBJ4) $(GISLIB)
> > > $(RASTERLIB) $(OBJ1):biowave2.h
> > > $(OBJ2):biowave2.h
> > > $(OBJ3):biowave2.h
> > > $(OBJ4):biowave2.h
> > > $(GISLIB):
> > > include tail.mk
> > > > Some lines of background (very fast, give me the chance :o)): the
> > > > wavelet filtering process creates from one map four maps of half of
> > > > the resolution. So every processing level takes map
> > > > 1
> > > > and creates four maps:
> > > > 2_11, 2_12, 2_21, 2_22
> > > > that have obviously same boundaries but different (half) resolution.
> > > > Next level takes the map of the lower resolution map
> > > > 2_22   (the others contain the difference values in x, y and xy)
> > > This was wrong, the lower resolution one is in the *_11, i.e. 2_11.
> > > *_22 is the xy diagonal direction.
> > > Alright, now the solution comes, even if it's a workaround version.
> > > Please take into account that when these modules were written, I was at
> > > my very first programming and grassprogramming experiences.
> > > Btw, the fact is that the modules work only for floating point FCELLs,
> > > i.e. not for integers and not for doubles. This is for sure due to some
> > > casting problem I could not deal with at the time (I feel ashamed...).
> > > The working result can be seen on 6 levels of decomposition the
> > > concave-convex zones of an island (twice you can guess which one :)):
> > > http://www.hydrologis.com/testfiles/waveletsscreens/images.html
> > > Next question will be: when will you fix this?
> > > I'm very busy at the moment and will not be able to fix that soon (did
> > > you ever go through the code of a beginning programmer?). So the only
> > > way now is to deal with floating point maps. Sorry for that.
> > > Cheers,
> > > Andrea
> > > > So the boundary are the same, but when I visualize, the result is the
> > > > following:
> > > > http://www.hydrologis.com/testfiles/wavelet_pbl.png
> > > > The bigger map is the third level of wavelet decomposition of the
> > > > smaller map. The boundaries are the same, so I can't understand why
> > > > the lower resolution map gets stretched.
> > > > In the last years did something change in the raster apis, which I
> > > > missed?
> > > > Sajith, can you try and tell me if you get the same results?
> > > > Has anyone some hint? I'm not really happy to go through some code I
> > > > didn't open for years if it is not really necessary.
> > > > > Also why r.wavelet is not part of grass6 distribution?
> > > > I guess because they seem not to work at the time :)
> > > > Honestly you are the second person that ask for multiresolution
> > > > analysis in 3 years, so I think that is why they are in the add-ons
> > > > section.
> > > > > Does it lacks something, like documentation?
> > > > No, the manual pages were made properly and exaustive.
> > > > Hope this can be solved,
> > > > Cheers,
> > > > Andrea
> > > > > On 7/3/05, Andrea Antonello <moovida at katamail.com> wrote:
> > > > > > Hi Sajith,
> > > > > > >        I am planing to do some image processing based on
> > > > > > > wavelet. I checked the r.wavelet module in the grass addon
> > > > > > > section, but it is made for grass 4(?). I wish to upgrade it to
> > > > > > > the present grass version.
> > > > > > the modules were made for the grass5 version. I got in touch only
> > > > > > once again with the wavelets modules in grass6, where they gave
> > > > > > some strange output, but at that time I had no second free to
> > > > > > understand what it was. Since the raster api didn't change
> > > > > > (someone correct me if it's not true), those modules should work
> > > > > > out of the box.
> > > > > > > I am not a grass developer now, and I dont know the changes in
> > > > > > > grass libraries between version 4 and 6.
> > > > > > > Can some one guide me on how to proceed?
> > > > > > What do you mean? Compilation into the release or usage?
> > > > > > The man pages in the package should fullfill the second.
> > > > > > However for a first quick use:
> > > > > > r.biowave.dec input=<mapname> output=<outputname> filter1=sp02.ir
> > > > > > filter2=sl05.ir filterpath=<folder where the filters (sp02.ir and
> > > > > > sl05.ir) are with / at the end>  NumRec=3
> > > > > > This will perform a 3 step wavelets decomposition.
> > > > > > The maps will be created and the names are selfexplanatory.
> > > > > > If I remeber correct, the starting map has to be floating point,
> > > > > > else there will be strange results.
> > > > > > Cheers,
> > > > > > Andrea
> > > > > > _________________________________________________________________
> > > > > >______ __ ___ HydroloGIS - Environmental Open Source Solutions
> > > > > > www.hydrologis.com
> > > > > > Andrea Antonello
> > > > > > Environmental Engineer
> > > > > > mobile:  +393288497722
> > > > > > "Let it be as much a great honour to take as to give learning,
> > > > > > if you want to be called wise."
> > > > > > Skuggsja' - The King's mirror - 1240 Reykjavik
> > > > > >______ __ ___
> > > _______________________________________________________________________
> > >_____ HydroloGIS - Environmental Open Source Solutions
> > > www.hydrologis.com
> > > Andrea Antonello
> > >_____
> > > grass5 mailing list
> > > grass5 at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grass5
> > Change the rules, or the rules will change you
> >      ---------Kumaranasan
____________________________________________________________________________
www.hydrologis.com
Andrea Antonello
