[GRASS5] PATCH: i.gensig
Markus Neteler neteler at itc.it
Fri Jul 22 03:44:30 EDT 2005
Brad,
I did a quick inspection - looks good to me.
Markus
On Thu, Jul 21, 2005 at 02:23:05PM -0700, Brad Douglas wrote:
> I need to clean up some old cruft I had not already committed to
> generate a clean, uncluttered patch for the tempfile issues.
> Any objections to the attached patch?  Just some benign updates to
> i.gensig to do with message output and localization.
> Brad Douglas <rez at touchofmadness.com>
> ? imagery/i.gensig/OBJ.x86_64-unknown-linux-gnu
> Index: imagery/i.gensig/check.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/check.c,v
> retrieving revision 2.0
> diff -u -r2.0 check.c
> --- imagery/i.gensig/check.c	9 Nov 2004 12:55:04 -0000	2.0
> +++ imagery/i.gensig/check.c	21 Jul 2005 21:18:31 -0000
> @@ -1,6 +1,9 @@
>  #include "imagery.h"
> +#include "glocale.h"
>  #include "signature.h"
>  #include "local_proto.h"
>  int
>  check_signatures (struct Signature *S)
> @@ -18,14 +21,14 @@
>  	if (!can_invert(temp.sig[0].var, S->nbands))
>  	    S->sig[i].status = -1;
> -	    fprintf (stderr, "Signature %d not invertible\n", i+1);
> +	    G_message(_("Signature [%d] not invertible,"), i+1);
>  	    continue;
>  	copy_covariances (temp.sig[0].var, S->sig[i].var, S->nbands);
>  	if (!eigen(temp.sig[0].var, lambda, S->nbands))
> -	    fprintf (stderr, "Signature %d can't get eigen values\n", i+1);
> +	    G_message(_("Signature [%d] can't get eigen values."), i+1);
>  	    continue;
>  	for (j = 0; j < S->nbands; j++)
> @@ -33,7 +36,7 @@
>  	    if (lambda[j] <= 0.0)
> -		fprintf (stderr, "Signature %d not positive definite\n", i+1);
> +		G_message(_("Signature [%d] not positive definite."), i+1);
>  		break;
> Index: imagery/i.gensig/covariance.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/covariance.c,v
> retrieving revision 2.1
> diff -u -r2.1 covariance.c
> --- imagery/i.gensig/covariance.c	13 Jul 2005 15:22:44 -0000	2.1
> +++ imagery/i.gensig/covariance.c	21 Jul 2005 21:18:31 -0000
> @@ -1,9 +1,11 @@
>  #include <stdlib.h>
>  #include "files.h"
>  /* must be called after compute_means() */
>  int compute_covariances (struct files *files, struct Signature *S)
> @@ -21,7 +23,8 @@
>      ncols = G_window_cols();
>      class    = (CELL *) G_calloc (ncols, sizeof(CELL));
> -    fprintf (stderr, "Calculating class covariance matri%s ...", S->nsigs==1?"x":"ces");
> +    G_message(_("Calculating class covariance matri%s ..."),
> +              S->nsigs==1 ? "x" : "ces");
>      for (row = 0; row < nrows; row++)
> Index: imagery/i.gensig/get_train.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/get_train.c,v
> diff -u -r2.1 get_train.c
> --- imagery/i.gensig/get_train.c	13 Jul 2005 15:22:44 -0000	2.1
> +++ imagery/i.gensig/get_train.c	21 Jul 2005 21:18:31 -0000
> @@ -1,8 +1,10 @@
>  #include <stdlib.h>
>  #include "files.h"
>  int get_training_classes (struct files *files, struct Signature *S)
>      int fd;
> @@ -23,11 +25,12 @@
>  /* determine the categories in the map */
>      I_init_signatures (S, files->nbands);
>      G_init_cell_stats (&cell_stats);
> -    fprintf (stderr, "Finding training classes ...");
> +    G_message(_("Finding training classes ..."));
>  	G_percent (row, nrows, 2);
> -	if (G_get_c_raster_row(fd, cell, row) < 0) exit(1);
> +	if (G_get_c_raster_row(fd, cell, row) < 0)
> +            G_fatal_error(_("Unable to read raster row."));
>  	G_update_cell_stats (cell, ncols, &cell_stats);
> @@ -49,15 +52,11 @@
>  		n++;
>  	    else
> -		fprintf (stderr,
> -		    "WARNING: Training class [%d] only has one cell - this class will be ignored\n", cat);
> +		G_warning(_("Training class [%d] only has one cell - this class will be ignored"), cat);
>      if (n==0)
> -	fprintf (stderr, "ERROR: training map has no classes\n");
> -	exit(1);
> +	G_fatal_error(_("Training map has no classes."));
>      list = (CELL *) G_calloc (n, sizeof(CELL));
>      n = 0;
> @@ -70,7 +69,7 @@
>      files->ncats = n;
>      files->training_cats = list;
> -    fprintf (stderr, "%d class%s\n", files->ncats, files->ncats==1?"":"es" );
> +    G_message(_("%d class%s"), files->ncats, files->ncats==1 ? "" : "es");
>      return 0;
> Index: imagery/i.gensig/main.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/main.c,v
> diff -u -r2.1 main.c
> --- imagery/i.gensig/main.c	13 Jul 2005 15:22:44 -0000	2.1
> +++ imagery/i.gensig/main.c	21 Jul 2005 21:18:31 -0000
> @@ -1,23 +1,25 @@
>  #include <stdlib.h>
>  #include "parms.h"
>  #include "files.h"
>  int main (int argc, char *argv[])
>      struct parms parms; /* command line parms */
>      struct files files; /* file descriptors, io, buffers */
>      struct Signature S;
> -	struct GModule *module;
> +    struct GModule *module;
>      G_gisinit (argv[0]);
>  	module = G_define_module();
>  	module->description =
> -		"Generates statistics for i.maxlik "
> -		"from raster map layer.";
> +		_("Generates statistics for i.maxlik "
> +		"from raster map layer.");
>      parse (argc,argv, &parms);
>      openfiles (&parms, &files);
> @@ -28,5 +30,6 @@
>      compute_covariances (&files, &S);
>      check_signatures (&S);
>      write_sigfile (&parms, &S);
>      exit(0);
> Index: imagery/i.gensig/means.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/means.c,v
> diff -u -r2.1 means.c
> --- imagery/i.gensig/means.c	13 Jul 2005 15:22:44 -0000	2.1
> +++ imagery/i.gensig/means.c	21 Jul 2005 21:18:31 -0000
> @@ -1,9 +1,11 @@
>  #include <stdlib.h>
>  #include "files.h"
>  int compute_means (struct files *files, struct Signature *S)
>      int n, n_nulls;
> @@ -19,7 +21,7 @@
> -    fprintf (stderr, "Calculating class mean%s ...", S->nsigs==1?"":"s");
> +    G_message(_("Calculating class mean%s ..."), S->nsigs==1 ? "" : "s");
> Index: imagery/i.gensig/opencell.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/opencell.c,v
> diff -u -r2.1 opencell.c
> --- imagery/i.gensig/opencell.c	13 Jul 2005 15:22:44 -0000	2.1
> +++ imagery/i.gensig/opencell.c	21 Jul 2005 21:18:31 -0000
> @@ -1,5 +1,7 @@
>  #include <stdlib.h>
>  #include "gis.h"
>  CELL *
>  open_cell (char *name, char *mapset, int *fd)
> @@ -9,6 +11,5 @@
>      if (*fd >= 0)
>  	return G_allocate_cell_buf();
> -    fprintf (stderr, "ERROR: unable to open raster map [%s]\n", name);
> -    exit(1);
> +    G_fatal_error(_("Unable to open raster map [%s]."), name);
> Index: imagery/i.gensig/openfiles.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/openfiles.c,v
> diff -u -r2.1 openfiles.c
> --- imagery/i.gensig/openfiles.c	13 Jul 2005 15:22:44 -0000	2.1
> +++ imagery/i.gensig/openfiles.c	21 Jul 2005 21:18:31 -0000
> @@ -1,7 +1,10 @@
>  #include <stdlib.h>
>  #include "parms.h"
>  #include "files.h"
>  int
>  openfiles (struct parms *parms, struct files *files)
> @@ -11,18 +14,12 @@
>      if (!I_get_subgroup_ref (parms->group, parms->subgroup, &Ref))
> -	fprintf (stderr,
> -	     "ERROR: unable to read REF file for subgroup [%s] in group [%s]\n",
> -		parms->subgroup, parms->group);
> -	exit(1);
> +        G_fatal_error(_("Unable to read REF file for subgroup [%s] in group [%s]."),
> +                parms->subgroup, parms->group);
>      if (Ref.nfiles <= 0)
> -	fprintf (stderr, "ERROR: subgroup [%s] in group [%s] contains no files\n",
> -	exit(1);
> +	G_fatal_error(_("Subgroup [%s] in group [%s] contains no files."),
>      /* allocate file descriptors, and array of io buffers */
>      files->nbands    = Ref.nfiles;
> Index: imagery/i.gensig/parse.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/parse.c,v
> diff -u -r2.1 parse.c
> --- imagery/i.gensig/parse.c	13 Jul 2005 15:22:44 -0000	2.1
> +++ imagery/i.gensig/parse.c	21 Jul 2005 21:18:31 -0000
> @@ -1,7 +1,10 @@
>  #include <stdlib.h>
>  #include "gis.h"
>  #include "parms.h"
>  int
>  parse (int argc, char *argv[], struct parms *parms)
> @@ -9,27 +12,27 @@
>      trainingmap = G_define_option();
>      trainingmap->key = "trainingmap";
> -    trainingmap->description = "ground truth training map";
> +    trainingmap->description = _("ground truth training map");
>      trainingmap->required = YES;
>      trainingmap->type = TYPE_STRING;
>      trainingmap->gisprompt = "old,cell,raster";
>      group = G_define_option();
>      group->key = "group";
> -    group->description = "imagery group";
> +    group->description = _("imagery group");
>      group->required = YES;
>      group->type = TYPE_STRING;
>      group->gisprompt = "old,group,group";
>      subgroup = G_define_option();
>      subgroup->key = "subgroup";
> -    subgroup->description = "subgroup containing image files";
> +    subgroup->description = _("subgroup containing image files");
>      subgroup->required = YES;
>      subgroup->type = TYPE_STRING;
>      sigfile = G_define_option();
>      sigfile->key = "signaturefile";
> -    sigfile->description = "resultant signature file";
> +    sigfile->description = _("resultant signature file");
>      sigfile->required = YES;
>      sigfile->type = TYPE_STRING;
> @@ -42,20 +45,13 @@
>  /* check all the inputs */
>      if(G_find_cell(parms->training_map, "") == NULL)
> -	fprintf (stderr, "ERROR: training map [%s] not found\n", parms->training_map);
> -	exit(1);
> +        G_fatal_error(_("Training map [%s] not found."), parms->training_map);
>      if (!I_find_group(parms->group))
> -	fprintf (stderr, "ERROR: group [%s] not found\n", parms->group);
> -	exit(1);
> +        G_fatal_error(_("Group [%s] not found."), parms->group);
>      if (!I_find_subgroup(parms->group, parms->subgroup))
> -	fprintf (stderr, "ERROR: subgroup [%s] not found\n", parms->subgroup);
> -	exit(1);
> +        G_fatal_error(_("Subgroup [%s] not found."), parms->subgroup);
>      return 0;
> Index: imagery/i.gensig/print_sig.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/print_sig.c,v
> diff -u -r2.0 print_sig.c
> --- imagery/i.gensig/print_sig.c	9 Nov 2004 12:56:10 -0000	2.0
> +++ imagery/i.gensig/print_sig.c	21 Jul 2005 21:18:31 -0000
> @@ -1,28 +1,28 @@
>  int
>  print_one_sig (struct Signature *S, int k)
>  	struct One_Sig *s;
>  	int i,n;
> -	FILE *fd;
> -	fd = stdout;
>  	s = &S->sig[k];
> -	fprintf (fd, "#%s\n", s->desc);
> -	fprintf (fd, "%d\n", s->npoints);
> +	G_message(_("#%s"), s->desc);
> +	G_message("%d", s->npoints);
>  	for (i=0; i < S->nbands; i++)
> -	    fprintf(fd, "%lf ", s->mean[i]);
> -	fprintf (fd, "\n");
> +	    G_message("%lf\n", s->mean[i]);
>  	    for (n=0; n < S->nbands; n++)
> -		fprintf (fd, "%lf ", s->var[i][n]);
> +		G_message("%lf\n", s->var[i][n]);
>  	if (s->have_color)
> -	    fprintf (fd, "%f %f %f\n", s->r, s->g, s->b);
> +	    G_message("%f %f %f", s->r, s->g, s->b);
> Index: imagery/i.gensig/write_sig.c
> RCS file: /grassrepository/grass6/imagery/i.gensig/write_sig.c,v
> diff -u -r2.1 write_sig.c
> --- imagery/i.gensig/write_sig.c	13 Jul 2005 15:22:44 -0000	2.1
> +++ imagery/i.gensig/write_sig.c	21 Jul 2005 21:18:31 -0000
> @@ -1,24 +1,23 @@
>  #include <stdlib.h>
>  #include "parms.h"
>  int write_sigfile (struct parms *parms, struct Signature *S)
>      FILE *fd;
>      fd = I_fopen_signature_file_new (parms->group, parms->subgroup, parms->sigfile);
>      if (fd == NULL)
> -	fprintf (stderr, "ERROR: unable to create signature file [%s] ", parms->sigfile);
> -	fprintf (stderr, "for subgroup [%s] in group [%s]\n",
> -	exit(1);
> -    fprintf (stderr, "Writing signature file [%s] ...", parms->sigfile);
> -    fflush (stderr);
> +        G_fatal_error(_("Unable to create signature file [%s] for "
> +	            "subgroup [%s] in group [%s]."),
> +                    parms->sigfile, parms->subgroup, parms->group);
> +    G_message(_("Writing signature file [%s] ..."), parms->sigfile);
>      I_write_signatures (fd, S);
> -    fprintf (stderr, "\n");
> +    G_message(_("Done."));
>      return 0;
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
