[GRASS5] [bug #3323] (grass) r.le.setup does not work properly
Jachym Cepicky jachym.cepicky at centrum.cz
Mon Jun 6 10:37:08 EDT 2005
hallo,
we try to make fragstats (http://www.umass.edu/landeco/research/fragstats/fragstats.html) work with grass. Paolo Cavallini knows more about this.
He says, that fragstats should be better, than r.le* modules in GRASS.
However, it seems, there is some bug in the code (Can not allocate space for
edge!), it would be good, if you could test r.frastats too, so that we know more
about this.
The package with r.fragsts can be downloaded here:
    http://les-ejk.cz/programs/grass/fragstats.tgz
It contains:
    * fragstats with support for GRASS-raster
    * r.fragststs -- GRASS-shell script for fragstats
    * files for QGIS (GRASS-Tools)
To install run
    ./configure --with-grass=/path/to/grass/inculde/dir ...
    make
    make install
I hope, it works :-)
Jachym
On Mon, Jun 06, 2005 at 03:02:25PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3323
> Subject: r.le.setup does not work properly
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs 6.1 end of Mai
> hello,
> running r.le.setup results in a stop after the last prompt - I have to do
> CTRL-C to get to the setup screen.
> > r.le.setup
> OPTION   Raster map to use to setup sampling
>      key:map
> required:YES
> enter raster map name:
> Enter 'list' for a list of existing raster files
> Enter 'list -f' for a list with titles
> Hit RETURN to cancel request
> > raster.1
> <raster.1>
> OPTION   Vector map to overlay.
>      key:vect
> required:NO
> Overlay a vector file? (y/n) [n]
> OPTION   Site map to overlay.
>      key:site
> required:NO
> Overlay a site file? (y/n) [n]
> .... stopped. no reaction.
> After CTRL-C the r.le.setup runs fine.
> Martin
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
