[GRASS5] [bug #3343] (grass) v.hull warns about using vector instead of sites
Request Tracker
grass-bugs at intevation.de
Sat Jun 11 15:39:06 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3343
Subject: v.hull warns about using vector instead of sites
Platform: WindowsNT/2000/XP
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.1.cvs
When using v.hull on a dbf file of points, I received the following warning:
WARNING: Vector used instead of sites
The command completed successfully. With the sites format removed is this warning still needed?
David Finlayson
-------------------------------------------- Managed by Request Tracker
