[GRASS5] PATCH: sql expression parser
Wed Jun 15 08:04:30 EDT 2005
Daniel Calvelo Aros wrote:
> > The SQL interpreter in the DBF driver doesn't have a negation
> > operator.
> > I thought about parsing -E as a subtraction (0 - E), although I'm not
> > sure whether there's something I'm overlooking.
> I'd rather use (-1)*E, which is also within the grammar, and I *think* works
> better wrt precedence rules and allows a*-b. I might be overlooking stg also.
Using (0 - E) will work just as well in that regard. I was initially
concerned about how to handle int-vs-float, but I've since confirmed
that the interpreter expands types:
	(int - int)   => int
	(int - float) => float
so subtracting the expression from integer zero should do the right
thing.
> What does e.g. octave do? BTW I'd use yacc's %prec, but that's just laziness
> of course.
It isn't parsing that's the issue, but what to insert into the parse
tree once a negation has been recognised.
The attached patch inserts a y_term type between y_product and y_atom,
with the definition:
y_term:
		y_atom				{ $$ = $1; }
	|	'-' y_term {
		    $$ = sqpNewExpressionNode ( sqpOperatorCode("-"), sqpNewValueNode ( NULL, 0, 0.0,  SQLP_I ), $2 );
This allows for negations to be negated, i.e. --E is interpreted as
-(-E). If this is not desired (I have no idea what the standard says
about this), then the line:
	|	'-' y_term {
would need to be changed to:
	|	'-' y_atom {
Index: lib/db/sqlp/lex.l
RCS file: /grassrepository/grass51/lib/db/sqlp/lex.l,v
retrieving revision 1.19
diff -u -r1.19 lex.l
--- lib/db/sqlp/lex.l	9 Sep 2004 20:02:23 -0000	1.19
+++ lib/db/sqlp/lex.l	15 Jun 2005 11:57:28 -0000
@@ -82,18 +82,6 @@
-  * ARITHMETICAL OPERATOR
-  * Conflict of  * as operator with * as all columns, what to do?
-			yylval.strval = (char*)strdup(yytext);
-			return ARITHMETICAL_OPERATOR;
   * COMPARISON OPERATOR
Index: lib/db/sqlp/yac.y
RCS file: /grassrepository/grass51/lib/db/sqlp/yac.y,v
retrieving revision 1.20
diff -u -r1.20 yac.y
--- lib/db/sqlp/yac.y	9 Sep 2004 20:02:23 -0000	1.20
+++ lib/db/sqlp/yac.y	15 Jun 2005 11:57:28 -0000
@@ -41,13 +41,17 @@
 	/* operators */
 %type <node>	y_column
 %type <node>	y_value
+%type <node>	y_atom
+%type <node>	y_term
+%type <node>	y_product
 %type <node>	y_expression
 %type <node>	y_comparison
-%type <node>	y_condition
+%type <node>	y_boolean
+%type <node>	y_sub_condition2
+%type <node>	y_condition
 	/* literal keyword tokens */
-%token <strval> ARITHMETICAL_OPERATOR
 %token <strval> COMPARISON_OPERATOR
 %token <strval> NAME
 %token <strval> STRING
@@ -194,13 +198,20 @@
 y_sub_condition:
-		y_comparison { $$ = $1;	}
-	|	'(' y_sub_condition ')' { $$ = $2; }
-	|	y_sub_condition AND y_sub_condition { $$ = sqpNewExpressionNode (SQLP_AND, $1, $3); }
-	|	y_sub_condition OR y_sub_condition { $$ = sqpNewExpressionNode (SQLP_OR, $1, $3); }
-	|	NOT y_sub_condition { $$ = sqpNewExpressionNode ( SQLP_NOT, NULL, $2); }
+		y_sub_condition2 { $$ = $1; }
+	|	y_sub_condition OR y_sub_condition2 { $$ = sqpNewExpressionNode (SQLP_OR, $1, $3); }
+y_sub_condition2:
+		y_boolean { $$ = $1; }
+	|	y_sub_condition2 AND y_boolean { $$ = sqpNewExpressionNode (SQLP_AND, $1, $3); }
+y_boolean:
+		y_comparison { $$ = $1; }
+	|	'(' y_sub_condition ')' { $$ = $2; }
+	|	NOT y_boolean { $$ = sqpNewExpressionNode ( SQLP_NOT, NULL, $2); }
 /* Note EQUAL should be one of COMPARISON but there is maybe some reason ... */
 y_comparison:
@@ -220,14 +231,36 @@
 /* Mathematical expression */
 y_expression:
-		y_value				{ $$ = $1; }
-	|	y_column			{ $$ = $1; }
-	|	y_expression ARITHMETICAL_OPERATOR y_expression {
-		    $$ = sqpNewExpressionNode ( sqpOperatorCode($2), $1, $3 );
+		y_product			{ $$ = $1; }
+	|	y_expression '+' y_product {
+		    $$ = sqpNewExpressionNode ( sqpOperatorCode("+"), $1, $3 );
+	|	y_expression '-' y_product {
+		    $$ = sqpNewExpressionNode ( sqpOperatorCode("-"), $1, $3 );
-	|	y_expression '*' y_expression {
+y_product:
+		y_term				{ $$ = $1; }
+	|	y_product '*' y_term {
 		    $$ = sqpNewExpressionNode ( sqpOperatorCode("*"), $1, $3 );
+	|	y_product '/' y_term {
+		    $$ = sqpNewExpressionNode ( sqpOperatorCode("/"), $1, $3 );
+y_term:
+		y_atom				{ $$ = $1; }
+	|	'-' y_term {
+		    $$ = sqpNewExpressionNode ( sqpOperatorCode("-"), sqpNewValueNode ( NULL, 0, 0.0,  SQLP_I ), $2 );
+y_atom:
+		y_value				{ $$ = $1; }
+	|	y_column			{ $$ = $1; }
+	|	'(' y_expression ')'		{ $$ = $2; }
 /* Value used in expressions */
