[GRASS5] PATCH: sql expression parser
Daniel Calvelo Aros
dcalvelo at minag.gob.pe
Sun Jun 19 18:24:42 EDT 2005
Ok, Glynn's latest patch compiles and seems to work under both MacOSX and
linux. I mean:
Input statement: -->>select a from b where -(1+a)/-(b+c)<1 and not a>2 or not
not a=1<<--
********** SQL PARSER RESULT **********
INPUT: select a from b where -(1+a)/-(b+c)<1 and not a>2 or not not a=1
COMMAND: SELECT
TABLE: b
COLUMN 1: a
WHERE:
op: OR
op: AND
op: <
op: /
op: -
val: 0
op: +
val: 1
col: a
op: -
val: 0
op: +
col: b
col: c
val: 1
op: NOT
op: >
col: a
val: 2
op: NOT
op: NOT
op: =
col: a
val: 1
ORDER BY: (null)
Paul, could you commit?
Daniel.
-- Daniel Calvelo Aros
---------- Original Message -----------
To: "Daniel Calvelo" <daniel.calvelo at minag.gob.pe>
Cc: grass5 at grass.itc.it
Sent: Wed, 15 Jun 2005 13:04:30 +0100
Subject: Re: [GRASS5] PATCH: sql expression parser
> Daniel Calvelo Aros wrote:
> > > The SQL interpreter in the DBF driver doesn't have a negation
> > > operator.
> > > I thought about parsing -E as a subtraction (0 - E), although I'm not
> > > sure whether there's something I'm overlooking.
> > I'd rather use (-1)*E, which is also within the grammar, and I *think* works
> > better wrt precedence rules and allows a*-b. I might be overlooking stg also.
> Using (0 - E) will work just as well in that regard. I was initially
> concerned about how to handle int-vs-float, but I've since confirmed
> that the interpreter expands types:
> (int - int) => int
> (int - float) => float
> so subtracting the expression from integer zero should do the right
> thing.
> > What does e.g. octave do? BTW I'd use yacc's %prec, but that's just laziness
> > of course.
> It isn't parsing that's the issue, but what to insert into the parse
> tree once a negation has been recognised.
> The attached patch inserts a y_term type between y_product and
> y_atom, with the definition:
> y_term:
> y_atom { $$ = $1; }
> | '-' y_term {
> $$ = sqpNewExpressionNode ( sqpOperatorCode("-"),
> sqpNewValueNode ( NULL, 0, 0.0, SQLP_I ), $2 ); } ;
> This allows for negations to be negated, i.e. --E is interpreted as
> -(-E). If this is not desired (I have no idea what the standard says
> about this), then the line:
> | '-' y_term {
> would need to be changed to:
> | '-' y_atom {
> Glynn Clements <glynn at gclements.plus.com>
------- End of Original Message -------
