[GRASS5] running grass on macosx
Terry Richards
sn00per1 at bellsouth.net
Sun Jun 19 18:14:56 EDT 2005
i have looked hi and low but i can't find why this happened.
i have read the tutorial and many other tips and emails that i found
using google. there is so much info out there that it is very complex. i
installed gdal, proj, R-2.1.0<failed>
i also tried the latest from cvs but ran into too many files not found
but are installed<jpeg,tiff,,png,postgres,fftw>
i have macosx 10.4.1 on tibook using grass61cvs...same with grass60
child process exited abnormally
while executing
"exec -- g.region vect=roads >@ stdout 2>@ stderr"
("eval" body line 1)
invoked from within
"eval exec -- $cmd $args >@ stdout 2>@ stderr"
(procedure "run" line 2)
invoked from within
"run $cmd"
(procedure "DmCmd::display" line 13)
invoked from within
"DmCmd::display $node"
("cmd" arm line 2)
invoked from within
"switch $type {
group {
DmGroup::display $node
raster {
DmRaster::display $node
labels {
DmLabels::display $node
(procedure "Dm::display_node" line 6)
invoked from within
"Dm::display_node $n"
(procedure "DmGroup::display" line 11)
invoked from within
"DmGroup::display "root""
(procedure "Dm::display" line 6)
invoked from within
"Dm::display"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.topf.tb0.bbox1.b0"
(command bound to event)
in the startup window i get:
Welcome to GRASS 6.0.0 (2005)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: d.m &
When ready to quit enter: exit
GRASS 6.0.0 (spearfish):~ > NavGetReply failed, -128
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
ERROR: vector map <roads> not found
