[GRASS5] r.flow -- support for NULLs
Jaro Hofierka hofierka at geomodel.sk
Mon Jun 20 03:48:16 EDT 2005
I believe that the barin raster accepts only 1/0 values. It defines flow
barriers.
But it makes sense to use 1/null values as well, where 1 is a barrier
and null is not a barrier. Clearly, it needs some update to accept both
or put this information in the manual page.
Jaro
Jachym Cepicky wrote:
> Hallo,
> I try some test on the Spearfish dataset with GRASS 6.1. Is it possible, that
> r.flow does not support NULL values at least for "barin" raster? I get the
> right output only with maps with "0" values..
> Jachym
