[GRASS5] running grass on macosx
Mon Jun 20 04:03:15 EDT 2005
> >>>Are you using the Lorenzo Moretti binaries, the MaxOSX binaries, or
> >>>something you compiled yourself?
> >>cvs don't compile
> >Is there a need to compile it? Lorenzo's binaries are brilliant.
> no i just gave compiling a try after the binaries didn't work
> out...how  do i tell if they are lorenzos or whatever?  i got them
> here:http://www.public.asu.edu/~cmbarton/files/grass_osx/
That is a mirror of Lorenzo's site:
  http://wwwamb.bologna.enea.it/forgrass/
Did you use the library installer that came with the GRASS 6 app from
Lorenzo's and did it work? Copy the app to /Applications, not just run it
from the package window? Did you install Lorenzo's Tiger patch needed for
his 6.0.0 release?
Hamish
