[GRASS5] v.in.ascii
Thomas Adams
Thomas.Adams at noaa.gov
Wed Jun 22 13:24:59 EDT 2005
Hamish,
So, are you saying if I have x,y,z data, I should use columns=3? What if
I have x,y,z,t data, where z is an elevation and t is some value? I
assume columns=4? Does GRASS know the difference between z and t?
Another question is how does this relate to gstat use within GRASS6;
does gstat know the variable I'm interested in is t and not z?
Regards,
Tom
Hamish wrote:
>>There was a change in in.c implemented 4 weaks ago see
>>http://freegis.org/cgi-bin/viewcvs.cgi/grass6/vector/v.in.ascii/
>>Could this have broken the example shown by Hamish?
>That's the one. The coltype2[] that gets sent to points_to_bin() on line
>389 is only populated if the columns= option is used. Otherwise it is
>being used uninitialized. No gcc warning for uninitialized pointers?
>Changing that back to "coltype" makes it work again for me.
>work-around: be sure to use columns=
>Hamish
>_______________________________________________
>grass5 mailing list
>grass5 at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grass5
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20050622/9efa0ce2/attachment.html
