[GRASS5] [bug #3362] (grass) r.proj works ONLY when source and
target mapset names are identical
Morten Hulden
morten at untamo.net
Wed Jun 22 21:09:21 EDT 2005
>> Paul Kelly wrote:
>>>> r.proj is not calling G_tempfile() directly. In the case mentioned
>>>> above suspects are datum.c, get_datum_name.c, get_ell_name.c or some
>>>> other function from /lib/gis files.
>>> Even so, it should be creating a temp file in the current mapset, not
>>> in the location that is being projected from. Perhaps the location
>>> switching
>>> code in r.proj might not be handling the mapset correctly. Although I
>>> tried to reproduce the problem and couldn't.
>> I could not reproduce the problem either; I was able to reproject from
>> a mapset where I did not have write permission, but r.proj did not
>> even try to create a .tmp directory anywhere in the source mapset.
>> OTOH I am running a CVS version a few weeks old. I'll update and see
>> what happens. Although r.proj has not changed some underlying library
>> routines may have ...
> With CVS 20050623 I get the same error:
> mkdir: cannot create directory
> `/var/local/grass/data/global_ll/morten/.tmp': No such file or directory
> ERROR: can't make mapset element .tmp/xxxx.yyyyyy.zzz
> (/var/local/grass/data/global_ll/morten/.tmp)
> So the bug was introduced in some library routines since 20050606 (last
> time I updated from CVS), but not in r.proj itself.
>> Paul Kelly wrote:
>> See
>> http://grass.itc.it/pipermail/grass5/2005-January/016997.html
>> I suspect Brad's recent changes to make G_asprintf() use G_tempfile()
>> should be reverted?
Yes, it's in G_asprintf(). Simply changing G_tempfile() back to
tmpfile() on line 37 in asprintf.c fixes it. There may be other
consequences so I suggest the maintainer makes the reversion himself in cvs.
rgds
Morten
