[GRASS5] v.in.ascii
Hamish
hamish_nospam at yahoo.com
Thu Jun 23 21:07:00 EDT 2005
Right, valgrind is done for 'v.in.ascii -zt'
I used the first 250,000 points from the sample lidaratm2 dataset.
http://bambi.otago.ac.nz/hamish/grass/memleak/v.in.ascii/
Three un-freed calls sum to 91% of the still reachable memory at program
termination. (roughly 300 bytes lost per vector point)
RTreeNewNode (node.c:47)
dig_alloc_line (struct_alloc.c:112)
dig_alloc_node (struct_alloc.c:46)
A test following children processes is running now, but I think the
above three are the major culprits. Will add these results to the page
later in the day. (but I'm running with -t so no DBF stuff)
Hamish
