[GRASS5] v.in.ascii
Radim Blazek
radim.blazek at gmail.com
Thu Jun 30 05:53:15 EDT 2005
On 6/30/05, Hamish <hamish_nospam at yahoo.com> wrote:
> > There is no leak in the library, the memory is not released by default
> > because it takes long time. You can force the library to release the
> > memory if you want using Vect_set_release_support().
No, to build topology you need spatial index for all points.
Radim
> Perhaps then a clean & non-invasive solution is to add a check to run
> Vect_set_release_support() once after each 100,000 points or so? or after
> each time the allocation grows to > 50~100mb.
> Can you safely run Vect_set_release_support() mid process?
> Hamish
