[GRASS5] Re: [bug #3023] (grass) r.fillnulls doesn't work
Hamish
hamish_nospam at yahoo.com
Tue Mar 1 21:24:39 EST 2005
> >> r.fillnulls fails in such a way:
> >> GRASS 6.0.cvs:~ > r.fillnulls input=N51E016_nowy
> >> output=N51E016_nowy.fld Using tmp file r_fillnulls_4707
> >> Locating and isolating NULL areas...
> >> 100%
> >> r.buffer: 00000000 - illegal distance specification
> > what do you get if you type this at a command prompt:
> > echo "0.3 0.3" | awk '{printf "%.8f\n", ($1 + $2)}'
> > 00000000 or 0.60000000 ?
> Neither:
> GRASS 6.0.cvs:~ > echo "0.3 0.3" | awk '{printf "%.8f\n", ($1 + $2)}'
> 0,00000000
> "," instead of "." - would that be the issue? I Poland, in opposite to
> the normal world, we use the coma as the decimal point deliminator.
> Does r.fillnulls rely on local system settings?
Yes, that's the problem.
I think awk might have troubles too. does this give "0,6":
echo "0,3 0,3" | awk '{printf "%.8f\n", ($1 + $2)}'
We can't assume "bc" or "dc" are installed, but come to think of it we
are using an arbitrary buffer distance here anyway so it doesn't really
matter if we are +/- 1m. I've just applied a fix in CVS removing the
above "awk" step. please test.
Hamish
