bug tracking: areas (was: [GRASS5] bugs)
Bernhard Reiter
bernhard at intevation.de
Wed Mar 2 03:44:18 EST 2005
On Wed, Mar 02, 2005 at 03:33:54PM +1300, Hamish wrote:
> > > - split it into two queues: grass5x and grass6x (with different
> > > links from grass web site); this would make it far easier to keep
> > > everything tidy, even if at the expenses of some replication
> > Two queues can be done by the tracker, but I would suggest
> > to use two links from the butracking page to archive the same.
> ...but any raster/lib bugs will affect both versions. Better to clear
> out all grass5.x-specific bugs from the bug tracker to the old
> grass/BUGS file in CVS, add a prominent link to that on the GRASS 5.4
> webpage & main bug reporting page, and go on from there?
No.
To put bugs in the file and remove them from the tracker should only
be done when, it is absoltely sure they do not get fixed
for that version (e.g. 5.4.x) and they do not apply to 6.x.
Usually it is better to keep the bugs in the tracker.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050302/72ede834/attachment.bin
